Old 02-22-2010, 11:38 AM   #11 (permalink)
90 day: 51.82 mpg (US)
Can you share what numbers you're currently seeing on your worn out lean-burn motor?
Post some more info in your intro thread and I'll add it to the project library.
http://ecomodder.com/forum/showthrea...sota-9198.html
Old 02-23-2010, 12:45 AM   #12 (permalink)
1991 RED Metro 1.0 Auto - '91 Geo Metro Lsi Auto
90 day: 38.28 mpg (US)
1991 3/5 2 door Blue/green - '91 Geo Metro
Last 3: 42.6 mpg (US)
If you're not into high RPM performance then 30 degree valve seats could show measurable improvement. (you can still have the 3 angles, just the seat/ contact point is 30 instead of 45)
Old 02-23-2010, 12:51 AM   #13 (permalink)
"Could" being the key word, as my understanding of it is that strategy can't be universally applied; some port/valve/chambers work better with 30 and some work better with 45. I personally wouldn't change any of my heads from one to the other unless there was an impressive body of work by accomplished cyl head guys that proves it to be a good move for my application.
Old 02-23-2010, 07:23 AM   #14 (permalink)
Well it depends on what/ how you look at "better", if you look at peak flow numbers 30 is usually worse. Peak lift only happens one time per cycle though, all points less than peak happen twice, it's all about the area under the curve. The 30 degree seat provides more curtain area at lower lifts in any engine, if I could I would do it to all my engines since I don't own any pure race vehicles the benefits far outweigh the drawbacks.
Old 06-09-2010, 04:38 PM   #15 (permalink)
I found a good read about 3 angle valve jobs, check it out:
1320network.com/2010/05/should-i-street-this-episode-1-3-angle-valve-jobs
He basically says it isn't worth it for street vehicles, and your money is spent better elsewhere.
Old 06-09-2010, 08:12 PM   #16 (permalink)
Porno Music Producer
zhillz's Avatar
lolwut - '98 Honda Civic EX
90 day: 47.5 mpg (US)
I though the air flow 'swirled' on the lean burn engines? Would this effect it?
Honda IACV explained TomO Off-Topic Tech 16 12-21-2015 01:49 AM
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 83 06-20-2015 11:30 AM
1992 Honda Civic VX for sale. Boston MA. Stock, factory AC, VX rims, new tires brakes civicvx For Sale 9 12-02-2011 09:47 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
