Old 05-13-2015, 03:44 PM   #1 (permalink)
90 day: 52.71 mpg (US)
90 day: 70.75 mpg (US)
90 day: 52.48 mpg (US)
Ford testing cylinder deactivation with 1.0L turbo 3-cyl Ecoboost engine: 6% gain
OK, you know things are getting serious when they start investigating cylinder deactivation in a triple.
Ford says they've been doing on-road testing of rolling cylinder deactivation in their 1.0L turbo, with a series of countermeasures to manage NVH:
They fitted the prototype (Ford Focus) with a newly developed system that combined a dual mass flywheel, a pendulum absorber, and a tuned clutch disc; and is particularly effective at low revs. As well as enabling a wider operating range of cylinder deactivation, this system helped counteract any effect that the cylinder deactivation had on levels of noise, vibration and harshness.
Fuel efficiency improvements were recorded in homologated conditions and during test drives of the first prototype vehicle, for a typical commuter distance of 55 km on a combination of motorway, city roads and rural roads, in and around Cologne, Germany. The development is a collaboration with Ford’s engineering partners at the Schaeffler Group.
The results: Fuel efficiency improvements of up to 6 per cent
The "rolling" deactivation approach means each cylinder takes turns being the deactivated one.
The benefit is a more well-balanced temperature level inside the combustion chambers and consistent firing intervals for three-cylinder engines operating in deactivation mode.
Source: Green Car Congress: Ford exploring cylinder deactivation for 1.0L EcoBoost; testing shows up to 6% fuel efficiency improvement
And Ford: https://media.ford.com/content/fordm...enhancing.html
The Following 3 Users Say Thank You to MetroMPG For This Useful Post:
aerohead (05-14-2015), Frank Lee (05-13-2015), UltArc (06-23-2015)
Old 05-13-2015, 03:48 PM   #2 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '10 Chevy Cobalt XFE
hmm a modern hit and miss engine.
The Following 2 Users Say Thank You to rmay635703 For This Useful Post:
Joggernot (05-14-2015), niky (05-14-2015)
Old 05-13-2015, 03:54 PM   #3 (permalink)
Put a big enough flywheel and muffler on it, and nobody'll be any the wiser!
Old 05-13-2015, 03:58 PM   #4 (permalink)
I must say I'm surprised by the 6% figure. Seems high to me considering that 1.0L engine still wants higher engine load on a Focus even...
Old 05-13-2015, 05:44 PM   #5 (permalink)
Every time I drive the T-Racer with it's 2.0L I think, "This car has waaaay too much engine"!
Old 05-13-2015, 06:18 PM   #6 (permalink)
The 1.8L Civic gave me the same reaction. I have never said the same thing about the Firefly/Metro though!
Old 05-13-2015, 06:37 PM   #7 (permalink)
With Metros I drop the "waaaay" but I think a 2-cyl Metro would suit me just fine; that is, if it gives me enough fe improvement.
Old 05-14-2015, 01:22 PM   #8 (permalink)
rmay635703's Avatar
Direct water injection on off cycles could recover even more free FE
Old 05-14-2015, 04:54 PM   #9 (permalink)
Furry Furfag
Baltothewolf's Avatar
Winsight - '00 Honda Insight
Miaderp - '95 Mazda Miata
90 day: 28.53 mpg (US)
Instead of making these damn cars harder to work on/diagnose, how about just more aerodynamic? That 6% will never pay for itself when it takes me an extra 2 hours to diagnose an engine misfire problem and I charge you 90$ an hour for labor.
Old 06-23-2015, 04:50 PM   #10 (permalink)
Tinkerer
kafer65's Avatar
Silver - '15 Mazda CX-5 Sport
Team Mazda
90 day: 37.23 mpg (US)
Looks like greencarcongress has a comparison of fixed cylinder deactivation versus rolling deactivation on Fords 1 liter triple. NVH, complexity and cost balanced in the comparison. Looks like fixed is winning out in the cost and complexity without loosing too much gains in mpg. I'm not a fan of using dual mass flywheels because they fail often and at great cost in the used car market. They use them to help overcome the shakes.
Mirror deletes, 80% grill blocks, wheel covers, 50 psi tires = 6% better MPG avg. over a year. Wheel skirts overcoming ethanol winter fuel mpg losses and more!
http://ecomodder.com/forum/showthrea...ead-30641.html
