Old 07-06-2008, 09:50 AM   #1 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Saw another grill block :)
I was at the zoo friday and noticed what looked like a gold pontiac, but it had the caracteristic "use whatever you have lying around" grill block job on it It had a little Bondo to close the hood gap and some black stuff on the lower grill. It weren't pretty unless you knew what it was about. I found it quite encouraging myself The stealth grill blocks are nice, but the obvious ones sure are a lot easier to spot.
Old 07-06-2008, 10:48 AM   #2 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 Honda CRX DX
90 day: 66.52 mpg (US)
Send a message via AIM to SVOboy Send a message via MSN to SVOboy Send a message via Yahoo to SVOboy
I don't think I've ever seen on in the wild, so that's pretty neat indeed.
Old 07-06-2008, 12:22 PM   #3 (permalink)
Depends on the Day
RH77's Avatar
Teggy - '98 Acura Integra LS
Sports Cars
90 day: 32.74 mpg (US)
IMA - '10 Honda Insight EX
90 day: 34.76 mpg (US)
Tessie - '06 Acura TSX Base
90 day: 28.2 mpg (US)
I've only seen cardboard type stuff in the Winter, but nothing in the warmer months. Excellent spot!
RH77
“If we knew what we were doing, it wouldn't be called research” ― Albert Einstein
_
_
Old 07-06-2008, 05:50 PM   #4 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
What...no piccies?
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 07-07-2008, 09:53 AM   #5 (permalink)
Mechanical Engineer
The Truck - '02 Dodge Ram 1500 SLT Sport
90 day: 13.32 mpg (US)
The Van 2 - '06 Honda Odyssey EX
90 day: 20.56 mpg (US)
GoKart - '14 Hyundai Elantra GT base 6MT
90 day: 30.4 mpg (US)
Godzilla - '21 Ford F350 XL
90 day: 8.69 mpg (US)
I've seen something here in the parking lot at work...late 90s/early 00's Sebring coupe with what looks like an aftermarket bumper cover that has rippled plastic in place of the standard open grille. Not a "grille block" per se but not-so-cleanly blocks the grille none the less. Since it's neither aero-clean due to the horizontal ridges approximating the original grille shape nor a DIY job I don't think the original intent was improved mileage.
Old 07-07-2008, 11:05 AM   #6 (permalink)
dcb
needs more cowbell
dcb's Avatar
Oh I forgot, the pontiac had the wipers parked vertically
Old 07-07-2008, 01:08 PM   #7 (permalink)
I read that grille blocks are ineffective. EPA blocked an 18 wheeler's grille oppening and there wasn't any effect in wind resistance. I have the PDF file somewhere hope I find it.
GreenTruckingConcepts.com
Old 07-07-2008, 01:38 PM   #8 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
I hate to feed the trolls, but you are aware that the aerodynamic differences between an 18 wheeler and a passenger car is ENORMOUS right?
Old 07-15-2008, 07:38 PM   #9 (permalink)
....sorry. I didn't know 'aerodynamics' CARED. I thought that they affected EVERYTHING ***PROPORTIONATLY****
I think the EPA tests are *smarter* than YOURS.
Old 07-15-2008, 08:37 PM   #10 (permalink)
Mr. Blue Tape
azraelswrd's Avatar
AzxA - '06 Scion xA
90 day: 42.72 mpg (US)
I wouldn't put a lot of weight into EPA tests, considering the thorough "testing" they do for mileage ratings.... assuming they actually do any testing and don't just take someone else's data and stick it into the computer and hope whatever value they do get is close to where it should be (plus those numbers they use are guesstimates to simulated aerodynamic effects).
...or the unrealistic conditions done for those tests re-established in the 80s, only updated after 2007? Wow, slow and sloppy. It's not surprising so many people here are able to overshoot the EPA expected values or worse by many others who don't know better, to undershoot it by a large margin.
Grille blocking can't hurt but it alone won't net you a lot of mpgs. It's all about the cumulative gain. 0.2 here, 0.4 there, 0.1 somewhere else... aeromods can add up.
My 5 pillars of fuel efficiency:
  • driving style
  • aerodynamics
  • tires
  • weight reduction
  • engine maintenance
The Following User Says Thank You to azraelswrd For This Useful Post:
Christ (11-05-2009)
Grill Block Poll. Ryland Aerodynamics 33 08-03-2017 11:30 AM
OEM Grill Block for 92-95 Civic Owners TomO EcoModding Central 6 12-21-2014 09:58 PM
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
My try at a partial grill block bhazard Aerodynamics 15 04-30-2008 10:09 PM
