Old 06-08-2010, 08:19 PM   #1 (permalink)
ChopsQube's Avatar
Nissan Cube - '10 Nissan Cube Base
90 day: 33.35 mpg (US)
The BRG - '91 Mazda Miata SE
90 day: 35.9 mpg (US)
Pulsing and coasting...
Just a couple quick questions because I have a 6-speed manual transmission....
1) When you finish coasting, do you blip the throttle to "rev-match" or just ease out the clutch?
2) After coasting and you're back in gear with the clutch out, how much throttle do you use to get back up to speed?
I just want to be sure I'm doing this right instead of just wasting gas.
Many thanks in advance!
Old 06-08-2010, 08:27 PM   #2 (permalink)
The Atomic Ass's Avatar
Overland - '24 Nissan Versa S 5MT
90 day: 38.64 mpg (US)
What your fillups return will be a great (if slow) indicator of success.
Old 06-08-2010, 08:39 PM   #3 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
1. It's better to blip the throttle to approximately rev match. It will save wear on the synchros.
2. There's no single answer, aside from accelerating at or near optimal engine efficiency. Wide throttle increases engine efficiency, but if you go too far, the ECU will enrich the fuel:air mixture. A ScanGauge is helpful here.
Old 06-08-2010, 10:51 PM   #4 (permalink)
Turbo Dan-O's Avatar
Little Red - '93 Geo Metro G10
90 day: 61.31 mpg (US)
Yea, speed matching will be better on your trans and clutch and also not slow you down any. As for throttle.....I am still trying to figure this out....
Dan-o
'93 Metro 3/5 FE project
'69 Chevelle 6.0
'65 Mustang I6 turbo/nitrous
'92 Silverado on the bottle
'85 SVO
'77 Taylor SS jet boat
http://ecomodder.com/forum/fe-graphs/sig4098a.png
Old 06-08-2010, 11:51 PM   #5 (permalink)
ChopsQube's Avatar
Dan-o
I haven't been doing the rev-matching though I kept thinking that I should since that's what I've always done when down shifting. Now I know and will start my blipping again!
I do have a SGII and I know that if I keep the "LOD" down below 86 I will stay in closed loop mode. Through a little in-town driving today, I have managed to repeat my WOT LOD at 78 almost every time, if not just a tad below.
Thanks guys!
Old 06-09-2010, 12:31 AM   #6 (permalink)
Pishtaco
SentraSE-R's Avatar
Mean Green Toaster Machine - '06 Scion xB
90 day: 48.92 mpg (US)
I barely kiss the clutch plates to start the engine. Then I rev match to pulse again. 83 LOD works well for accelerating in both my SE-R and xB. 83 LOD is moderate acceleration in the xB. It's spirited acceleration in the SE-R.
Darrell
Boycotting Exxon since 1989, BP since 2010
Have you ever noticed that anybody driving slower than you is an idiot, and anyone going faster than you is a maniac? George Carlin
49.5 mpg avg over 53,000 miles. 176% of '08 EPA
Best flat drive 94.5 mpg for 10.1 mi
Longest tank 1033 km (642 mi) on 10.56 gal = 60.8 mpg
been playing with pulsing and coasting... olderthanme Hypermiling / EcoDriver's Ed 3 01-28-2008 09:32 AM
