Old 11-21-2010, 06:27 PM   #1 (permalink)
3n3rgystar's Avatar
Silver Bullet - '92 Nissan Sentra XE
90 day: 37.59 mpg (US)
1989 Plymouth Voyager MANvan
Ecomods made
Here are the mods that I have done. Best MPG I got was 54.3 MPG. Four month average is 29.7 not too bad for a 3,000 lbs wedge shaped vehicle.
1.Roof rack (OEM as well as aftermarket) (deletion)
2.Side mirror/s (delete)
3.Radio antenna (relocation/deletion)
4.Shave badges, door handles, rain gutters, etc
5.Mud flaps (deletion)
6.Windshield wiper (deletion)
7.Semi Smooth wheel covers
8.Advanced ignition timing
9.Power steering reduction
10.Mechanical to electric radiator fan swap (not applicable)
11.Increase tire pressure to max sidewall
12.Weight reduction 305 lbs 4%
13.Replace tires with skinniest tires recommended by OEM
14.General maintenance
15.Hot / warm air intake
16.Upgraded thermostat from 192^ to 195^
17.Fixed oil leak on valve cover
18.Fixed pcv leak
19.Alligned wheel
20.remove intake elbow
21.reduce idle
22.remove carpet and reat bumper
23.Regap plugs with wider plug gap
24.Use lowest viscosity engine oil recommended by OEM
25.Synthetic oil
26.Tire spats
27.Full Grill Block(overheated) so went with a 3/4 block
28.Synthetic transmission/differential oil
29.Use thinnest transmission / differential oil recommended by OEM
check feasibility of removing beam axle(checked can not remove might could replace with lighter part.
remove heated air flap in airbox inlet
- play with cam timing via offset keys
- K&N drop in filter
hotter coil
- cooler thermostat, remove coolant lines to TB
- bore out TB
- modify butterfly (shave shaft, shorten screws, knife edge leading side)
ported head
- shave head to raise compression
Electric coolant / water pump
Lightweight wheels
Replace tires with low rolling resistance tires
Increased compression ratio
CHECK- missing or defective thermostat, causing low operating temperature
CHECK - clogged intake manifold exhaust crossover passage (for heating intake manifold)
CHECK- engine misfire caused by bad spark plug, ignition wire, coil, dist. cap or rotor
CHECK- late ignition timing
CHECK- bad vacuum advance unit (common in old cars)
CHECK- stuck centrifugal advance mechanism in distributor (needs oil occasionally)
CHECK- bad tension adjustment of centrifugal advance springs
CHECK- defective oxygen sensor (causes rich mixture)
CHECK- defective coolant temp. sensor for engine computer (causes rich mixture)
CHECK- worn timing belt (may cause rich fuel mixture in fuel injected cars with a MAP sensor)
CHECK- incorrect timing belt installation (timing marks should line up)
CHECK- sticking or poorly adjusted carburetor choke (causes rich mixture)
CHECK- dirty air filter on an engine with a carburetor (causes rich mixture at high power)
CHECK- clogged or defective PCV valve
- incorrect valve clearance (especially if too tight)
- high performance camshaft installed (not efficient at low power)
CHECK- worn valve guides (makes fuel mixture too lean at low power)
CHECK- vacuum leak from bad vacuum hoses or intake system gaskets (causes lean mixture)
CHECK- dirty fuel injectors
CHECK- bad fuel pressure regulator
CHECK- bad MAP sensor for fuel injection
CHECK- leaking intake duct between air flow sensor and throttle body
CHECK- too much alcohol in gasoline with old car (requires carb. modification for correct mixture)
CHECK- rusted or missing exhaust heat stove or pipe for heated air intake
CHECK- loss of compression pressure due to worn rings or leaking valves
CHECK- sticking EGR valve (causes rough idling and rich mixture on some engines)
CHECK- exhaust backpressure caused by clogged catalytic converter, muffler or crushed pipe
CHECK- stuck exhaust manifold valve for some V type engines. Intended for fast warm up.
CHECK- high idle speed
CHECK- high fast idle speed when cold
CHECK- incorrect idle mixture adjustment (carburetor or fuel injection)
CHECK- leaking fuel line or carburetor (dangerous too)
CHECK- clogged jets (calibrated holes) inside carburetor
CHECK- defective power valve in carburetor
CHECK- worn camshaft lobes
CHECK- high alternator voltage (should be about 14 volts when warm)
CHECK- high oil level (interferes with crankshaft movement)
CHECK- high oil pressure (relief valve stuck or has wrong spring)
CHECK- stuck cooling fan clutch (runs fan when not needed)
Problems that increase rolling resistance:
CHECK- sticking disk brake calipers
CHECK- tight drum brake adjustment
CHECK- warped brake rotor or drum
CHECK- sticking parking brake cable
CHECK- incorrect wheel alignment, front or rear (check tire wear)
CHECK- worn suspension joints (ball joints, steering joints)
CHECK- worn control arm bushings (changes wheel alignment)
CHECK- worn or incorrectly adjusted wheel bearings
CHECK- leaking grease seals for wheel bearings
CHECK- use of snow tires when not needed
CHECK- leaking tires, causing loss of pressure
CHECK- warped tires
CHCEK- bent rims, causing car to shake
CHECK- poor wheel balance, causing shaking at high speeds
CHECK- worn shocks or springs (forces driver to brake more)
Automatic transmission problems:
CHECK- wrong fluid level
CHECK- incorrect throttle valve cable adjustment
CHECK- bad vacuum modulator or vacuum hose to modulator
CHECK- sticking valves in valve body, causing delayed shifts; changing transmission fluid may help
CHECK- failure of torque converter to lock up (if equipped with lock-up torque converter); it should engage at 30-55 MPH, reducing engine speed about 10%
CHECK- stuck stator clutch in torque converter
Differential problems:
CHECK- excessive oil viscosity
CHECK- bad bearings
CHECK- high ratio ring and pinion gear set installed for racing
hotter coil
- bore out TB
Well, the cheap tricks are:
- Index your spark plugs so the gap faces the intake manifold
- Insulate your fuel lines
- If your head gasket is made up of a few pices overlapped, you can remove usually 2 of the 3 metal gasket pieces that overlap and gain engine compression.
- If it's a honda, do a Mini me (vtec head on non vtec car)
- Strip all excess weight from the car (this incldes interior), lighten your bumpers, delete the rear wiper, sunroof, any electric motors not needed, AC system
- Get better suspension. This does make a difference (tokico is good, perhaps new energy susp. bushings
- Cool your fuel before a race
- Get lighter rims
- Direct airflow to intake manifold (get rid of the airbox)
- use synthetic oil (if applicable)
- relocate your intake air temp sensor (FI cars)
- lighten the flywheel
Just notes i had from the mods. See the ugly pics of the man van.
ID:	7406   Click image for larger version
Old 11-21-2010, 09:34 PM   #2 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Nice job on the van. Nice write up too.
Old 11-21-2010, 09:34 PM   #3 (permalink)
3n3rgystar's Avatar
Ohh should have put my starting point was 18.2 mpg average. 27.8mpg best before I started doing all the mods.
Old 11-21-2010, 09:40 PM   #4 (permalink)
3n3rgystar's Avatar
Thanks, seems to need editing some but was handy when I dug in and started doing all the mods on my day off work. Seems side advantages are the van is much faster when needed, has a higher cargo capacity, handles better due to reduced weight on suspension, and doesn't look so girly anymore...lol
Old 11-21-2010, 11:35 PM   #5 (permalink)
Post up a fuel log, and tell me about that mechanical fan.
Old 11-22-2010, 08:27 AM   #6 (permalink)
3n3rgystar's Avatar
thats one of the things that needs to be edited as it did not have a mechanical fan so that one does not apply. would have to find some time to do the fuel log upload as i did it on paper.
Old 11-22-2010, 08:44 AM   #7 (permalink)
3n3rgystar's Avatar
things on my wish list
get turbo
get 5 speed manual trans
reduce weight some more
Old 11-22-2010, 06:03 PM   #8 (permalink)
It was on the list of things you've already done
Old 05-09-2011, 07:41 AM   #9 (permalink)
3n3rgystar's Avatar
Put the muffler back on and getting 5 mpg better with it back on, plus its quieter.
Old 05-09-2011, 10:58 AM   #10 (permalink)
Yay! Tell all your buddies about your finding too! Spread the news!
1989 Honda CRX HF for Sale -- 55 mpg Raysp30 For Sale 11 04-25-2012 11:18 AM
Some help with my voyager Nerys EcoModding Central 18 06-09-2011 03:58 PM
My 1989 Geo Metro Story owlafaye Introductions 2 10-05-2008 06:31 PM
Mom's 1999 Plymouth Voyager results ankit EcoModding Central 21 03-28-2008 01:03 PM
