Old 04-08-2010, 08:20 AM   #11 (permalink)
PaleMelanesian's Disciple
hummingbird's Avatar
City - '04 Honda City iDSI EXi
90 day: 47.47 mpg (US)
Ask for thinnest tolerable oil when you change oil next. That is one thing that affects FE, and you don't get a chance to change it every week. If synthetic, better, but it cuts deeper in the wallet. Clean up junk in the boot. Take off any silly overhead rails/carrier/spoiler and clean out the boot. Lighter the better.
(Feels nice here to be on the other side, as I have mostly been asking stuff rather than telling ;-)
And I run my tires at 50 PSI, even when my guru Pale here is a bit shy admitting to his figure :P
Old 04-08-2010, 08:32 AM   #12 (permalink)
The Crimson Crawler - '04 Hyundai Elantra GLS
90 day: 36.71 mpg (US)
Side note. DO NOT DO NOT DO NOT turn off any Hyundai automatic transmission while rolling! NO EOC! They use some sort of rubberized clutch packs that can't take it. I just got an '04 Elantra and it says absolutely NO "flat-towing" or moving for any distance with the engine off. You can shut off at red lights, any coast up maybe a few car lengths, but no more than that.
I guarantee you that you can get it to 35 MPG! I have a bigger car, and I'm already there - check it out.
Watch your tire pressures, and try not to rev it over 2500 at any point. Once you get used to 2500, try to push that down to 2k.
Congrats, welcome, and good luck!
The Following 2 Users Say Thank You to Nevyn For This Useful Post:
cfg83 (04-08-2010), jkp1187 (04-08-2010)
Old 04-08-2010, 12:36 PM   #13 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
carbonx -
Listen to Nevyn's warning. I make the assumption that Auto trannies cannot EOC until after I have done lots of research on them. The "no flat tow" definitely means no EOC. Automatics that are designed to be flat towed (for example, cars that can be attached to mobile homes) are usually fine, but research is always in order.
CarloSW2
American Solar Energy Society
Old 04-08-2010, 01:10 PM   #14 (permalink)
comptiger5000's Avatar
RaceJeep - '98 Jeep Grand Cherokee (ZJ) 5.9 Limited
90 day: 13.62 mpg (US)
The tranny in my Jeep isn't safe for EOC either, unless I put the t-case in neutral. The problem is, the t-case isn't synchronized, so it would be somewhere between hard and impossible to get it engaged again.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 04-08-2010, 09:25 PM   #15 (permalink)
Think gasoline is expensive? Weigh it against the cost of rebuilding an automatic tranny. Been there, done that...
"Hypermiler" pulled over for driving too slow SVOboy Hypermiling / EcoDriver's Ed 100 11-02-2009 11:11 PM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 01:28 PM
New Member, trying to save some money 5 O'Clock Charlie Introductions 6 09-02-2008 11:20 PM
4 Day School Weeks To Save Fuel Matt Herring EcoModding Central 9 07-25-2008 03:12 PM
