Old 06-07-2013, 09:35 PM   #11 (permalink)
Originally Posted by jmmbmd2013ph View Post
only a few people here have made that kind of mod, I was also thinking about it but its way too expensive and we never had diesel corollas released here in the Philippines. so it would be hard to find a half-cut with a 2C diesel on it.
What about the Isuzu 4FB1 or 4FC1? Those are also good option for the Corolla
Old 06-14-2013, 09:10 AM   #12 (permalink)
Dr. J
jmmbmd2013ph's Avatar
Just an update I used WD-40 on my engine and lubricated and sprayed on the following parts:
1. alternator
2. water pump pulley
3. a/c compressor
4. tensioner bearing
5. main crankshaft
I also sprayed the internal of my contact point type distributor and the ends of my high tension wires and sparkplug ends with WD-40 and results were remarkable, my engine is now running smoother and more quiet, and even with all of my accessories open (e.g. lights, a/c, radio, etc.) the RPM does not drop that too low.
also, I just finished doing a DIY installation of customized cold air intake, I hope it performs well tomorrow
BTW can you guys suggest a design for a hypermiling sticker that I can put on my rear glass? i'm planning to put one soon...
Old 06-14-2013, 12:18 PM   #13 (permalink)
Cyborg ECU
California98Civic's Avatar
90 day: 66.42 mpg (US)
90 day: 3671.43 mpg (US)
... also, I just finished doing a DIY installation of customized cold air intake, I hope it performs well tomorrow
In general, on this site, you'll find testing showing warm air intakes a benefit (or no change) to FE. In general cold air intake systems are understood to improve power modestly and reduce FE a little.
Get the "ecomodder.com" sticker by donating to the EM site (or just buying one)... promote the community!
Old 06-14-2013, 05:44 PM   #14 (permalink)
Dr. J
Cool
good day! thanks for the reply, I already tried a warm air intake on my SOHC 1,3 Carb engine and I ended up stepping up the gas more often due to lack of power, so I'm still going to try out this one, I'll update soon
