Old 02-05-2014, 12:23 PM   #1 (permalink)
New Owner of a 1981 4door VW Rabbit Diesel**47.5MPG**Baseline
I will post pic later today.of this 1.6L N/A 5speed yellow monster.
The top end is suppose to be rebuilt and the block was ok. Runs good and I just drove it home yesterday so I have to see my baseline MPG.
Things to do:
  • Replace the 4 worn shocks
  • Replace front signal lights (not working)
  • Install E-brake cable
  • Remove passenger mirror
  • put Aerodynamic front bumper, maybe a Euro Plastic one
  • Move outside antena to inside
  • have my Diesel Mechanic cousin give it a good look
  • Look into lighter rim/tire package...I think it has 14 or 15in steelies
Things I hope to eventually do are the Giles Fuel Pump.
I also had a 3300lb car with manual brakes and it was doable, so converting this to manual brakes would make engine bay alot cleaner. Not sure if there is a manual brake conversion kit for these MK1's?
side note: the engine doesnt have the AC unit at all and no moonroof..yeah..The car drives plenty fast and honestly way faster than I anticipated. fun as heck!
Here we go
The Following 2 Users Say Thank You to bigchelis For This Useful Post:
Cobb (02-05-2014), Joggernot (02-06-2014)
Old 02-05-2014, 02:10 PM   #2 (permalink)
Does putting a smaller or muffler removal do anything for MPG's/HP on these?
Any air filter mods that would increase MPG/HP?
Thank you,
bigC
Old 02-05-2014, 04:25 PM   #3 (permalink)
Here is the 1.6 N/A diesel engine. No AC unit at all.
I wonder what else I can remove to make the engine more efficient?
Previous owner made a DIY cold air kit, but this engine like most diesels runs cold. Maybe I need to get rid of it.
Car has a Oil Heater already and it works too.
Old 02-05-2014, 04:30 PM   #4 (permalink)
Jyden's Avatar
Enduro E-bike - '11 PowerPedals Enduro
90 day: 2236 mpg (US)
Jota - '14 Toyota Yaris Hybrid H1
90 day: 53.11 mpg (US)
Bigger dia exhaust will do some good on that car. Also keep cold air intake - it good for milage on diesels like the old rabbit.
Pump up tires to max, and do some grill blocking and a front airdam.
The good about the old rabits is that they dont wigh so much.
Good luck with it.
My Yaris Hybrid thread:
http://ecomodder.com/forum/showthrea...s-c-27995.html
Old 02-05-2014, 05:42 PM   #5 (permalink)
If it has the factory exhaust it should be a 4 to 2 to 1 tri Y header and down tube. The GTI exhaust is a bit bigger for the 1.8 engine and gives more flow. THe PCV tube coming down on top of the air filter is great for fouling it. You may want to add a washer inside the pcv or crank case breather hose thats right on the top rear of the valve cover to keep the oil in the engine.
Yes, get a free-er flowing filter. Dont recall if the diesels like that like hot or cold air. They made a super charger for those that is driven by the cam sprocket,but its hard to find.
Yeah, my father was a fan of the type 17. His was crushed by a tree in one of the hurricanes that came up the east coast.Maybe Gastone? The dasher has a 1.3 engine or 90 cid, so that is a bit larger.
Old 02-05-2014, 06:05 PM   #6 (permalink)
Black sheep 2013 - '11 Volkswagen Jetta S
90 day: 29.01 mpg (US)
black sheep 2014 - '11 volkswagen jetta trendline plus
90 day: 29.78 mpg (US)
Black sheep 2015 - '11 Vw Jetta mk6
90 day: 22.42 mpg (US)
lucky ******* Peanut Butter interior, i would do a Kamm on the rear and block the front
Old 02-05-2014, 06:34 PM   #7 (permalink)
Thank you all.
Ok. So, a bigger exaust system is a definite.
The PVC is the cold air per say. I may block that off and get rid of the flexible tubbing and close it off with a filter type screen. I think Diesels run better warm and this one runs cold all the time.
The Cam cover is in the trunk, I will put that on this weekend and hopefully some shocks.
An air dam and Euro Plastic front bumpers with some grill blocking are also a good and hopefully cheap way to increase mpg.
I also want to make the car nicer looking so, fix some dents and bruses the car has on the exterior.
Thank you all,
bigC
Old 02-06-2014, 11:18 AM   #8 (permalink)
I just realized it has those stock 13in steel rims.
175/70 R13
So, I dont think I can find lighter rims than those.
Old 02-06-2014, 01:02 PM   #9 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
Just a hint that your camera lens might by dirty...we love pics and the clearer they can be the more we like them.
Nice find. My friend had one of those growing up. Cool car.
2013 Honda Civic Si - 2.4L
OEM front to back belly pan from the factory.
The Following 2 Users Say Thank You to LeanBurn For This Useful Post:
Cobb (02-06-2014), UltArc (02-10-2014)
Old 02-06-2014, 04:41 PM   #10 (permalink)
Jyden's Avatar
Old Rabbit diesels like cold air, and as free a flow as possible.
