Old 10-30-2015, 06:39 PM   #1 (permalink)
A new welding technique.
This may help make "composite" bodies more viable in the near future.
https://news.osu.edu/news/2015/10/29/vfaweld/
The Following 5 Users Say Thank You to RustyLugNut For This Useful Post:
ByDesign (11-01-2015), darcane (10-30-2015), freebeard (10-31-2015), JRMichler (10-31-2015), pgfpro (10-30-2015)
Old 10-30-2015, 06:50 PM   #2 (permalink)
darcane's Avatar
I can see galvanic corrosion still being an issue, but a very intriguing technique.
Past Cars:
2001 Civic HX Mods
CTS-V
2003 Silverado Mods
Old 10-31-2015, 11:42 AM   #3 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 37.93 mpg (US)
Micro explosive welding - cost effective, versatile, and can weld without destroying parts. But no KABOOM.
I used to work at a place where the owner heard about explosive welding, so he went out into his backyard with some dynamite and experimented.
Old 10-31-2015, 01:20 PM   #4 (permalink)
I don't get it. The exploding strip of aluminum forces the one material against the other? Like a spotweld?
OTOH, galvanic corrosion requires an electrolyte. The welds themselves are in close contact, maybe unwelded areas might be a problem.
Old 11-01-2015, 10:56 AM   #5 (permalink)
Sounds interesting... wonder if this means you'll need a jig or a form to weld on... or if it is possible to simply align the parts in a body shop, slap the explosive strip along the area you want the seam at, and set it off...
Old 11-02-2015, 03:09 AM   #6 (permalink)
Send a message via MSN to markweatherill
Part of the process must be setting the parts together, plus the explosive, so that the energy goes where intended. For example, making sure the parts don't weld themselves to the jig.
Old 11-02-2015, 05:55 AM   #7 (permalink)
For lack of a betteer plan, I went back and read the linked article; and I found a link to
https://iml.osu.edu/vaporizing-foil-...ght-structures
This pressure pulse from the expanding gas can be used to drive workpieces for various purposes, such as forming, shearing, tube expansion, and small-scale collision welding.
Where there is a video
Old 11-02-2015, 03:47 PM   #8 (permalink)
For anyone still interested, heres the Impulse Manufacturing Laboratory at OSU channel on Youtube:
https://www.youtube.com/channel/UCKw...4kIfJ1Q/videos
They have ten videos up. Similar to hydroforming, this is a process that allows small scale forming and welding that would be done with explosives on a larger scale. Generally the forms for something the size of the palm of your hand is constructed with 1 1/2" steel plates and 3/4" bolts. The explosive foil is like an old VW Beetle fuse (both types!). And it's set off inside a blast cabinet.
