Old 10-06-2010, 07:32 AM   #1 (permalink)
Silver Bullit - '98 BMW 318ti Sport
90 day: 39.37 mpg (US)
Hindenburg - '05 Ford Crown Victoria Police Intercepter
Newbie w/ a BMW 318ti
Hello all,
Just thought I'd introduce my self.
I've been driving my 318 for ten years and she has 230k on her
I commute 100 miles a day on long flat Fl highways
it makes ridge riding and constant throttle driving easier.
I have changed the rear diff to a 2.79lsd from a E30 eta
Put on taller skinnier tires
If do all highway driving I can get up to 39mpg.
Cecil
Old 10-06-2010, 09:21 AM   #2 (permalink)
turbothrush's Avatar
2 x wrecked vx - '92 Honda Civic Vx
90 day: 62 mpg (US)
Was the Diff swap a bolt-in for your 318 ? I had been thinking of getting a 325eta as a highyway machine but maybe your high geared 4 cylinder swap is even better !
Old 10-06-2010, 10:20 AM   #3 (permalink)
Diff Swap
Turbothrush
The ti's use the E30 rearend
All other E36 use a newer E36 rear
The Eta rear is a bolt in for the ti, and they are cheap because no one wants them.
If you were to buy an E36 318 to get four doors, then you could use a six cylinder 2.93 and get the same result.
Or just get a 1991 318i, which is an E30 body style with four doors and buy an Eta diff.
Cecil
Old 10-06-2010, 11:08 AM   #4 (permalink)
Black Beauty - '09 Honda Accord EX-L
90 day: 27.44 mpg (US)
Originally Posted by kekle View Post
Hello all,
Cecil
Really cool setup you have there. Not many people are confident enough to do that with a BMW.
Thanks for sharing!
We are glad to have you here at Ecomodder.com!
Old 10-06-2010, 02:52 PM   #5 (permalink)
I used to drive one of those. I swapped in a 3.64 from the original 4.1. It was a good compromise. E30s had an over drive 5th so the ETA diff would 20% taller than in the E36.
cheers
Interview with BMW aerodynamicist Hans Kerschbaum Piwoslaw Aerodynamics 13 06-11-2010 04:59 PM
BMW will supply diesel engines for US police cars Piwoslaw General Efficiency Discussion 2 03-25-2010 07:33 PM
Article: BMW Plans All-Turbo Line RH77 General Efficiency Discussion 2 10-10-2008 12:10 AM
Speed vs. MPG: 1996 BMW 318ti MetroMPG General Efficiency Discussion 0 01-24-2008 10:45 AM
