Old 03-26-2012, 01:06 AM   #1 (permalink)
newbie here with ford ranger
hey all im rob , just got a 2000 ford ranger 2.5L 4 banger with a manual trans.
So far from what i can tell from using how many litres i use and my odo im getting about 29 mpg pure city. Is this good? Im planning to make a bigger chin spoiler , grille block and tape the gap between the cab and box shut this week any sugestions for better stuff to do? Aero cap is out of the question as i am a contractor and use the bed daily but happy to hear your thoughts!
-rob
Old 03-26-2012, 06:02 PM   #2 (permalink)
have goten 29mpg after adjusting my driving style a bit and using higher gears when cruising hopefully this will help even more!
well did some reading on the site and had some time this afternoon so did some areo mods.
lower chin spoiler with winglets and little deflectors in front of the rear wheels and a grille block
Old 03-26-2012, 06:40 PM   #3 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder.
29mpg in city traffic is pretty good - if they're US gallons - as the ecomodder members' Ford Rangers top out around 33mpg (US)
See
EcoModder Fleet list - EcoModder.com
A bit less good if they're imperial gallons, but then you have more room for improvement
If you click on the Rangers in the list, you can often read, see ( or click through to) what they've done to get better mpg.
Like Conor's page :
https://picasaweb.google.com/1022893...349/Ecomodding
An easy mod is increasing tyre pressure, if you hadn't already.
Looks like you've already added an air dam up front - bring it at least as low as the lowest underbody parts.
Keep an eye on the coolant temperature when adding a grille block, especially as summer is drawing closer.
An underbelly pan also helps, as does reducing the size of the wheel arcs and flat covers on the rims.
As for driving style - are you coasting in neutral already ?
If not, give it a try, even if you may be reluctant to do so at first - I know I was.
It'll really help your city mileage - it certainly did for me.
(Hard-core hypermilers will even shut down the engine during coasting - which cuts out powersteering instantly, and power brakes after a few dabs at them).
It takes a bit of practice to see what speed will get you to the next turn, light, stop sign, or whatever, at an appropriate speed.
Old 03-27-2012, 04:55 AM   #4 (permalink)
yeah im using us mpg and im running the tires at 50 psi already. I have been 'granny'driving and coasting in neutral alot too. Next mods will electric fans instead of belt driven and mudflap removal. Il add some pics 4 yall
Old 03-28-2012, 09:47 AM   #5 (permalink)
90 day: 51.82 mpg (US)
Hey Rob - welcome to the forum.
I'd also look into getting instrumentation if you haven't already. ScanGauge, Ultragauge, that kind of thing.
It'll help keep you tune your driving technique and keep you motivated by letting you turn driving into a "high score" game.
Darin
Old 03-28-2012, 09:54 AM   #6 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 80.56 mpg (US)
Send a message via MSN to jakobnev
It seems like wing+cover could be made with very little effort, and also be made so that it could be reconfigured or removed easily if it got in the way of cargo.
The Following 2 Users Say Thank You to jakobnev For This Useful Post:
itsageo (03-28-2012), MetroMPG (03-28-2012)
Old 03-28-2012, 02:59 PM   #7 (permalink)
thanks guys im gonna try out the spoiler thing and metro mpg u remember me from teamswift? Thats how i found this site originaly lol
Old 03-29-2012, 06:15 AM   #8 (permalink)
itsageo! Yup, I was wondering about your username.
Old 04-14-2012, 04:43 PM   #9 (permalink)
I also have a Ranger 4 banger. You're doing well! I'm lucky to get 25 around town. I'm starting to get into better habits. One thing I do is let it lose 5 MPH at the top of every hill, then get it back on the other side.
