Old 01-19-2010, 04:22 PM   #11 (permalink)
The XT - '92 Yamaha XT225 Serow
Last 3: 80.67 mpg (US)
White Civic - '08 Honda Civic Hybrid
90 day: 38.23 mpg (US)
Blue and White Beast - '78 Ford F150
90 day: 11.33 mpg (US)
Red T100 - '93 Toyota T100
90 day: 14.7 mpg (US)
Originally Posted by PaleMelanesian View Post
The problem with most manual transmissions these days is they have these high-revving gear ratios. The autos often have lower-rpm ratios, which offsets the inherent inefficiency of an automatic. If the ratios were the same, the manual should/would rate higher on the epa test.
True. I assumed an "all other things equal" in autos vs. manuals. Two reasons for the ratio differences spring to mind. One, sticks may be marketed more for performance so they're geared for acceleration. Two, carmakers are compensating for the fact that autos typically have lower effective ratios at the torque converter stall speed. I do know that sticks still rule in over the road trucking where FE is critical to make money. Eaton actually makes manuals with automatic clutches now.
Old 01-19-2010, 04:50 PM   #12 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
Sweet! Maybe my wife and I can agree on this car! She wants a Fusion, but I want 40+ mpg for her 40 mile commute to work and for traveling as a family. This has both (well, not a fusion, but similar styling quality - just a pinch smaller.)
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 01-19-2010, 06:05 PM   #13 (permalink)
B2300 - '96 Mazda B2300 SE
Focus - '05 Ford Focus ST
The red car - '00 Honda Insight
Sticks have shorter gears than the auto because with cruise control it can maintain speed or accelerate while stuck in top gear. The auto can downshift while in cruise if it needs to.
Now, I can see an aftermarket segment for tall freeway gears for those that realize that thier shifting arms and legs aren't broken once they reach freeway speeds.
The newest Focus looks great now. I hope it looks just as good when it comes to market in the US.
Didn't some Civics and Accords come with thermostatically controlled grilles?
Good design is simple. Getting there isn't.
Old 01-19-2010, 06:07 PM   #14 (permalink)
...beats walking...
...anybody remember (from way back during the "good ole days") the "add-on" tailshaft overdrive units?
...I had one installed on my '53 flathead Ford Crown Vickie!
Old 01-20-2010, 12:02 AM   #15 (permalink)
They should not hamstring the manual *unless* you order it with cruise control! I want tall gearing, and I almost never use cruise control, damn it!
I'm curious to know what these cars weigh, and what the Cd is...
Old 01-20-2010, 01:32 PM   #16 (permalink)
Neil, I hear ya!
If they don't offer an MPG optimized model, Ford Motorsports or someone should offer a taller final drive or 5th or something.
I see some sort of aftermarket segment potential directed at this. Sort of like what the Metro crowd has done.
My 'old' 2002 Ford Focus gsimpson Success Stories 17 01-21-2014 05:40 PM
New 2012 Ford Focus to be available as EV and Hybrid! NeilBlanchard General Efficiency Discussion 5 01-13-2010 04:05 PM
New 74.2 mpg ford focus econetic suspectnumber961 EcoModding Central 4 12-06-2009 05:26 AM
"New" 2007 Ford Focus Wagon akcapeco EcoModding Central 2 07-02-2009 01:23 PM
Ford Focus aerodynamics question Formula413 Aerodynamics 20 05-11-2009 06:34 PM
