Old 03-12-2012, 03:43 PM   #11 (permalink)
90 day: 51.82 mpg (US)
I wonder if it's a faulty MPG calculation.
You need to completely fill the tank to be able to figure MPG accurately. It sounds like you're just adding £10 or 20 at a time and trying to figure it out from there, which is not precise at all.
See: http://ecomodder.com/forum/showthrea...rmula-352.html
Old 03-12-2012, 08:52 PM   #12 (permalink)
radioranger
When In doubt change the O2 sensor , they are pretty cheap on Ebay . also the plugs, When ever I have trouble now I just go through the basic stuff that's cheap first , otherwise you go right past the problem, often while changing normal tune up items, I find things wrong but it still runs, How is the PCV valve, they plug up believe it or not ,mine did and blew out the valve cover gasket. could even be low baterry voltage, new cars and old need the full 13 volts to run good.
Old 03-13-2012, 12:09 AM   #13 (permalink)
The road not so traveled
TheEnemy's Avatar
The Truck - '99 Nissan Frontier xe
90 day: 25.74 mpg (US)
The Ugly Duck - '84 Jeep CJ7 Rock crawler
A friend with a different car than that had lost power and FE, it turned out to be the O2 sensor. It did not start running right immediately after changing it. It took about 60 miles for the computer to catch up and get the fuel trim back in line. After that it ran fine.
