Old 09-17-2010, 04:40 AM   #1 (permalink)
Honda VX engine not performing???
I've just done an engine swap in my '95 Civic and put in a VX (VTEC-E) engine and I'm missing something because I'm not getting any better gas mileage than my 450,000kms, old, stock, 16V, single overhead cam that I swapped out???
I've put in new spark plugs, distributor cap, air filter, oil change. What am I missing?
Old 09-17-2010, 09:10 AM   #2 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Prius C - '12 Toyota Prius C
Out of curiosity, which hemisphere are you in, what are you using for FE instrumentation, and did you swap over the VX ECU as well?
Old 09-17-2010, 09:38 AM   #3 (permalink)
Meph's Avatar
240Z - '73 Datsun 240Z 240Z
90 day: 34.41 mpg (US)
just to rule this out, you have the VX ecu too?
Old 09-17-2010, 12:47 PM   #4 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
what body and transmision are you using?
I also assume that you replaced things like your timing belt before putting the engine in, did you set the cam marks to the top of the head like most cars have or did you set them to the VX cam marks? it's a whole notch difference on the belt and greatly affects mileage and performance.
Old 09-17-2010, 02:37 PM   #5 (permalink)
I've got the VX ECU, it's single stage and kicks in at 5,000 rpm. I got a JDM engine and did not replace the timing belt, but thanks for the cam setting. I have '95 Civic CX hatchback, I'm not using FE instruments, but my commute has been the same for 10 years so I pretty well know my consumption, I live near Barrie Ontario, Canada, and work at the Toronto airport, around 150kms a day,(90 miles). I put in 5th gear at 80kph and run at around 2,500rpm. By the way do you use less gas to lug 5th gear on hills or change down to 4th?
Thanks for the replies
Old 09-17-2010, 11:37 PM   #6 (permalink)
Ok after searching through this site I've found that I should have a 5 wire oxygen sensor and I have a 4 wire. Also they put a non-stock 4 into 2 exhaust manifold. It sounds like it makes a big difference so I'm going to try and find the stock manifold and O2 sensor.
Old 09-18-2010, 12:07 AM   #7 (permalink)
Meph's Avatar
check your compression too, you may have issues with wear and tear
Old 09-18-2010, 09:05 AM   #8 (permalink)
Ryland's Avatar
5,000rpm is way to fast for the 2nd cam lob to kick in, it should be set for 2,500rpm, that is if you got the vtec-e engine.
Old 09-18-2010, 01:56 PM   #9 (permalink)
Really? wow thanks for telling me, I'm going to see the shop I bought it from on Monday, how can I tell if it is a real VTEC-E? Do I have to take the valve cover off to see if it's roller cams or is there an easier way? Thanks anyway, I have been known to be a little gullible!
Old 09-19-2010, 01:05 PM   #10 (permalink)
Ryland's Avatar
The valve cover is really easy to pull off, so pull it off and check to see if every other intake rocker arm runs on an almost round lob at lower speeds, you might also take a few photos of your engine and post them to see if anyone notices anything odd about it.
93 civic vx, Honda guy here. nskforlife Introductions 7 09-10-2010 08:15 AM
Honda VX intermittent speedo issue NachtRitter Off-Topic Tech 13 08-07-2010 09:21 PM
VX Info...WARNING: lots of info! TomO Off-Topic Tech 1 01-05-2010 12:39 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Alternative cars to honda VX? Daveedo General Efficiency Discussion 10 01-20-2009 05:05 PM
