Old 04-22-2012, 01:12 PM   #1 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Question Constant 12+ amps to SuperMID, yet shuts off
I wired my SuperMID to a prong on the fuse box that is showing a constant 12+ amps even with the key out of the ignition.
However, the SuperMID works only with the key in the ignition.
I used to have the SuperMID hooked up to where it would stay on at all times. ( at night the lit screen would stay on even with the key out . ) I can't recall where I had it hooked in before .
What have I done wrong, because the SuperMID seems to work, yet it shuts down as I shut off the car.
I tried to wire in with the radio, but I must have the wrong wire, because I have to turn the key on to get current.
The radio needs the key to function anyways, so I thought I would try the fuse route.
Old 04-22-2012, 01:41 PM   #2 (permalink)
NightKnight
NachtRitter's Avatar
RippinRoo - '05 Subaru Legacy Wagon 2.5 GT
Subaru
90 day: 21.16 mpg (US)
Helga - '00 Volkswagen Jetta TDI
Diesel
90 day: 53.91 mpg (US)
Olga - '03 Volkswagen Jetta Wagon
90 day: 46.24 mpg (US)
I'm hoping you mean 12 volts?
Old 04-22-2012, 02:13 PM   #3 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Uhhhhhh . 12volts, 12 amps, 12 megawatts ....all the same right ?
Mods could you please delete this thread as well as my others related to the SuperMID* ?
I found the problem anyways ( pretty sure I had the VSS in place of the power wire. ) and its cluttering up the forum.
( * Or just keep it for laughs )
power, supermid
