Old 12-01-2010, 05:07 PM   #1 (permalink)
noob
got 97 1.9 td jetta 5 spd. best mileage 44 mpg. what do you all think about swapping 195 60 14 tires for 195 70 14 (1.5ish taller)tires then moderately lowering?
Old 12-01-2010, 05:37 PM   #2 (permalink)
I'd try it. Maybe if you're not really committed to the idea or sure of it's success, you could score a pair or four cheap junkyard tires for a trial run.
Old 12-01-2010, 08:47 PM   #3 (permalink)
RSX2fast4mpg - '02 Acura RSX Type S
90 day: 38.22 mpg (US)
bubbatrucker - '98 Chevrolet K1500
90 day: 18.1 mpg (US)
Double check with a dealer or tire shop that has a compatibility book that they'll clear the wheel wells first. You should be fine, but some cars really don't leave much room for change.
Old 12-01-2010, 08:50 PM   #4 (permalink)
was thinking about trying, they would increase the radius of tire by 3/4" tops but cover about 7% more ground thanstock. i can start out at idle in 2 nd gear with this thing
Old 12-01-2010, 09:28 PM   #5 (permalink)
eco....something or other
wood hauler - '91 Ford F-250
Team Pontiac
90 day: 26.69 mpg (US)
Rav - '06 Toyota Rav4 Base
90 day: 26.52 mpg (US)
I have larger tires on my truck and they give an increase of about 5% + or-.
I am either covering more ground at the same revs or turning fewer revs at any given speed. I guess it depends on how I want to look at it. Either way it is a plus. I will continue to run larger tires. I have been getting about 28 mpg in the truck by the odometer, but the real mileage is about 30!
Go for it!
1991 F-250:
4.9L, Mazda 5 speed, 4.10 10.25" rear
Old 12-01-2010, 09:30 PM   #6 (permalink)
Team Pontiac
BTW...you would be getting about 47 mpg.
1991 F-250:
Old 12-02-2010, 01:57 AM   #7 (permalink)
just wanted to see what you guys thought or experienced... made sense in my mind...simple math & physics
Old 12-02-2010, 02:29 AM   #8 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
markz -
I went here and repeated your calculations. It would be a 6.6% gain with the new tires. If the odometer said 60 MPH, you'd actually be going 64 MPH. The wheels would raise the car up by 0.75". I agree that this is a cool mod.
Just to ask my standard-issue questions. Would the new tires fit on the same wheels and would the new tires fit in the wheel-well? Also, what is the before/after weight difference of the tires?
CarloSW2
American Solar Energy Society
Old 12-02-2010, 08:41 AM   #9 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Welcome to ecomodder.
44mpg as a best value isn't spectacular in that car with a TD or TDi engine - which one do you have ?
I've driven both engines to around 50mpg in similarly sized cars, and I wasn't really trying hard back then. No mods at all.
There were no dedicated low rolling resistance tyres then, either.
I'd suggest to start with changing your driving style and/or technically checking out the car before you start doing serious modifications to it.
Old 12-02-2010, 09:34 AM   #10 (permalink)
carlos... the tires have same section width so to my understanding should be good for a go, wieght difference maybe a pound per tire?
euro... mpg # calculated with us gallon which is 3.78l, i think imperial is 4.18? also done on my regular 360km route averaging 100km/hr, has a lot of long 6-8% grades. on a different route i took last summer it seemed to do better.
thanks for the welcome guys
Hi guys. Noob here /w 1988 Mercedes 300TE ps2cho EcoModding Central 8 06-01-2008 11:29 PM
Cycling Noob smsimpson83 Alternative Transportation 17 05-02-2008 05:49 PM
Noob here COMP Introductions 10 04-25-2008 12:43 PM
Plain and Simple I'm a complete Noob! RunninRedline Introductions 11 04-08-2008 07:31 PM
