Sorry, its where you are coming to a stop and you turn the key off and shift to nutral an coast. The Focus I drove had an automatic starter, so all you had to do was give the key a quick twist and it would crank til the engine fired up, shift to drive and go again.
You can do this as a modified pulse n glide technique.
