03-07-2012, 10:17 AM
Chevy Cruz ECO Owner
Hello everyone, I bought a chevy cruz eco about six months ago and am getting about 37.2MPG based on the OEM computer for combined driving. I am thinking about adding rear wheel fairings, but am undecided about the easiest way to make them so they look like a factory option. Im contemplating using an english wheel to roll out some aluminum panels and use camlock fasteners to mount them to the wheel opening. Does anyone know how close to the ground I can make them without worrying about a flat tire or a flat tire and a fully compressed suspension driving them into the ground? What Other mods might I consider that would not effect the looks of the car too much or void the warranty?
Also, If anyone knows the guy who posted the photo of what I think is an Alfa Romeo BAT speeding across the desert, I would like to get his permission to use the photo on a project Im working on.
03-07-2012, 11:33 AM
Ecomodder
Welcome to the site.
I have some pics of the BAT cars I took when they were on display in Vegas.
Got a couple nice and close up.
I'll have to root through my external hard drives to find them.
Lifetime mpg
2012 mpg
03-07-2012, 12:00 PM
Extend a line back from the bottom of the rocker panel just ahead of the wheel arch and you'll have your answer. (The rocker won't hit the ground under full suspension compression, or with a flat tire.)
Have you looked through this list?
65+ Efficiency Mods
03-07-2012, 12:08 PM
...beats walking...
"Welcome Aboard!" You anywhere near Glynco, GA?
03-07-2012, 12:22 PM
Im amazed at all the replies so far.
I will check that list out. Thanks!
Glyco, I have only been there once, but it was a beautiful part of GA! Im way up in the other corner of the state, Dade, County, near Chattanooga.
Images: this is the one Im looking for the creator of.
03-07-2012, 01:07 PM
Ecomodder
That looks more like a VW 1L with BAT style fins.
Lifetime mpg
2012 mpg
03-07-2012, 01:19 PM
Welcome to the site. I second checking out the link MetroMPG posted and will add this one. Its probably even more important and with it you should easily be seeing 40+ mpg in city and highway driving.
100+ Hypermiling / ecodriving tips & tactics for better mpg - EcoModder.com
03-07-2012, 01:38 PM
I think you are correct. I believe the image is a computer generated montage of the BAT and VW combined and not a real car...entirely. I revised it further and created more ground that isn't real.
Whomever did the original graphics work was really good!
03-07-2012, 01:57 PM
#9 (permalink)
Have you checked your fuel economy gauge against your actual fuel use? I ask because I have heard that the Cruze Eco over reports mpg's by 7-9%
03-07-2012, 02:30 PM
#10 (permalink)
I have not calculated it manually lately, but I did when i first bought the car and found it reasonably accurate, but I will check it again this week and post the results.
