Old 12-12-2012, 10:27 AM   #11 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
words of wisdom.
I find that the easiest mpg improvement came when I was driving at cruising speed (50-60pmh)for the majority of my drive.
THe aerodynamic improvements kick in and the larger tires lower the final rpm. Also the engine has warmed up.
If you have short commute or hilly terrian, then it becomes more dependent on driving skills. TIming the lights, coastto stops etc.
just my humble opinion.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 12-12-2012, 10:28 AM   #12 (permalink)
Originally Posted by mcrews View Post
Yes, You can adjust your scangauge for over/undersize tires.
I set my scangaugeII using my Garmin Nuvi GPS. I'm 9% off in my Kia.
wow I didn't expect you could do that, that settles it for me. I'm getting one of these!
Old 12-12-2012, 11:35 AM   #13 (permalink)
90 day: 55.97 mpg (US)
90 day: 70.75 mpg (US)
90 day: 61.17 mpg (US)
Not getting up to operating temp is a big red flag for fuel economy. The engine is running rich, and the transmission is probably holding lower gears to get the engine up to temp. If you have somewhere to plug in your block heater, I'd definitely put that at the top of the list (along with a gauge). You shouldn't need more than about 2 hours of pre-heat time.
Old 12-12-2012, 11:41 AM   #14 (permalink)
mcrews's Avatar
perry, if using a gps, the switch to meters and set on meters, you can change back to miles. Meters give you a more accurate reading
ECO MODS PERFORMED:
First: ScangaugeII
