Old 01-04-2010, 11:28 AM   #11 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Originally Posted by dremd View Post
I don't know? anybody else here run them?
Here are the tire rack reviews of them
Michelin Energy MXV4 S8
I also have no Idea how much I wore them in track conditions . . .
If you ran them at the track, you throw away any inkling of an idea that they may last for a predetermined mileage. 40k is good for an average-line tire, though. I think the Energy series tires are rated some 40k anyway.
Old 01-04-2010, 12:32 PM   #12 (permalink)
oldscoob - '87 subaru wagon gl/dr
90 day: 47.06 mpg (US)
Probably me, but to be fair the difference in tread depth is ~1.5mm except at shoulder where the tread was deeper to start with. And appears to be shifted toward the inside potentially indicating that my "slammed" suspension is throwing the alignment out . . . . Also I may have worn the shoulder more with track time . . . ..
That tire did good indeed. FWD and a racy car. That is more difficult than a sloppy ball joint on a heavy half ton truck.
suspension must be way down and stiff I could guess.
Discussion on tire efficiency Ernie Rogers General Efficiency Discussion 69 12-27-2014 02:17 PM
Measured my tire wear (20,000+ miles at elevated pressure - 44 PSI) moorecomp EcoModding Central 43 06-15-2012 01:23 AM
Riddle Me This! Abnormal Tire Wear trebuchet03 General Efficiency Discussion 22 06-04-2012 11:46 PM
LR Horrible Tire Wear Noel Off-Topic Tech 3 06-03-2011 07:47 PM
Tread Wear Rating and Rolling Resistance SVOboy EcoModding Central 12 08-31-2009 10:56 AM
