Old 05-29-2010, 10:00 PM   #21 (permalink)
OBDuino coder
Magister's Avatar
Titine - '13 Hyundai Sonata Hybrid
You are welcome
2013 Hyundai Sonata Hybrid
Old 06-05-2010, 10:16 AM   #22 (permalink)
halos.com
ECONORAM - '07 Dodge RAM 1500 QC SLT flex-fuel
90 day: 18.16 mpg (US)
the Avenger - '08 Dodge Avenger SXT
90 day: 27.06 mpg (US)
Send a message via Yahoo to ECONORAM
Okay, a little update for everyone. My wife's 08 Avenger needs the distance set at 103%, and fuel at 108%. I still need to try advanced sleep, but everything else works.
Old 06-06-2010, 09:41 AM   #23 (permalink)
OBDuino coder
Magister's Avatar
Thnaks you this is pretty cool, if you want to do a review with pics/video/whatever i could put it on my web page
Old 11-10-2010, 09:34 PM   #24 (permalink)
halos.com
Magister/everyone, got an update. Advanced sleep didn't work in the Avenger.
I did plug the OBDuino into my 07 Dodge RAM w/4.7L flex fuel (CAN bus) and it worked! I didn't try to calibrate it (sure looked funny as it was showing figures 2x that of the MPGuino, but that makes sense since the engine is twice as big as the Avenger's).
I need to sit down a while and customize some menus. Moving and then getting a new job kinda put a kink in my plans...
All that said, I really appreciate/enjoy being able to monitor instant mpg, as it keeps me more aware of what my driving style is doing to fuel use...
Old 11-11-2010, 09:38 AM   #25 (permalink)
OBDuino coder
Magister's Avatar
Thanks for the update
Old 01-19-2011, 12:05 AM   #26 (permalink)
halos.com
The wife and I took a trip in the Avenger last week to southern Mississippi and I used the OBDuino, as usual. I have grown rather accustomed to having it in the car, monitoring data inputs as I drive. First things first:
I ordered it from Magister because it was CAN, and figured it would be easier to get working in the car than the MPGuino that I put in my truck. Magister asked me what color LCD I wanted, and I asked for white because it will match the dash lighting. It is spot on, so kudos to Magister! The OBDuino took a little more than a week to arrive, but I figure that is not bad considering it has to go across the Canadian border. Well packaged and protected for the journey too. It comes with a right angle OBD connector that I see most sites charge extra for, and the other end plugs right into the OBDuino.
It differs from the MPGuino in that you do not hardwire it into the vehicle; you can however VIN lock it so it cannot be used in another vehicle (nice touch). You must turn the ignition on to power it up, as it gets power from the CAN bus. This was a little hard for me to get used to as I had expected it to be just like the MPGuino in my truck, which is powered up all the time. It displays fuel flow, BIG inst mpg, BIG current mpg, tank mpg, miles to empty, idling fuel burnt and other parameters like an MPGuino. HOWEVER, it also shows you outside temp, coolant temp, ignition advance, calculated engine load and other parameters that are available BECAUSE it is using the CAN bus. Quite handy for me on this last trip, as my Tstat seems to be getting weak and opening early. Car would only hit 175* on the highway...I could not tell by just watching the "temp gauge." (With an Ecomodder inspired grill block, it stayed at 183*.) NOTE: not all of these parameters are shown as it reaches you...you need to go into the second display editing option in order to choose what parameters you wish to see on which gauge display. I learned it is best to remember which parameters you want to change, not which corner you want to change, as I ended up switching the wrong ones more than once with the latter method. The BIG inst mpg is what I tend to leave it on for my wife, but when I drive I set up the first "quad" screen to show inst mpg, current mpg, tank mpg, and miles driven (to check the odometer against mile markers). The second quad screen I modified to display inst mpg, ignition advance, coolant temp, and calculated engine load. I figure these are good for me to monitor as I cruise down the road. They also help me maintain better fuel economy as I drive up hills...foregoing the cruise control. I should also mention that Dodge vehicles do not have a MAF sensor, so the fact the OBDuino displays inst mpg despite this is one thing I was looking for. There are 3 buttons. First once does the screen cycling, the second gets you into the adjustment menus, and the third button is basically a screen intensity adjustment.
Things I have noticed:
1. the device froze on our drive into Dallas last week...for about 30 minutes. I let Magister know today, but do not know if this is an isolated incident or not. The unit seemed to wake up after that stall, and worked as advertised after that.
2. I wish I had asked for an SD card daughter board, as that would have been useful to record data for testing purposes.
3. Ethanol fuels skew the fuel measuring. I have noticed this affects my MPGuino as well as the OBDuino. I figure if you can determine what the fuel blend is, you can figure out the compensation values for each, and just make the adjustments based upon what you put in the tank.
Would I recommend it? YES. IF you have a CAN bus vehicle, and want a less expensive alternative to the Scangauge, YES. It works well and gives 90%+ of us the info we need to help monitor the vehicle and modify our driving habits while saving fuel. The remaining 10% will want something much more robust or a combo tuner/gauge setup... Also, since Magister has some LCD color options, you can customize it to a degree for your interior. It is as small as the MPGuino, so you have man options for mounting the device in the vehicle. See the enclosure thread for some ideas: http://ecomodder.com/forum/showthrea...-off-6873.html
I should also add that I mentioned earlier I had to set the OBDuino to 103% for mileage because my car's odometer is that far off when I measured it against mile markers. Set at 100%, it is within 1% of the odometer. So, I am actually getting a more accurate mpg result from the OBDuino than I get from the car!!
Old 01-19-2011, 09:03 AM   #27 (permalink)
OBDuino coder
Magister's Avatar
Thumbs up
Wow, thanks for the review!!
I am working on a new version, well, a respin, I will try to use surface mount component and design an enclosure for it
EDIT: about the problem when it's below 0°C, I can see in my code that if the intake temp is negative it skips it thinking it's a timeout or a fault, I'll correct it and send you a new chip.
OBDuino Feature Request... electromike OpenGauge / MPGuino FE computer 13 07-23-2009 02:46 PM
Canadians make 4-wheel version of teardrop Dymaxion car in 1938 MetroMPG Aerodynamics 7 04-13-2009 11:36 PM
OBDuino and the 328p? gone22 OpenGauge / MPGuino FE computer 0 04-12-2009 09:56 PM
News: Toyota unveils production version of Smart car competitor MetroMPG General Efficiency Discussion 8 09-06-2008 12:58 AM
The UnNamed Wagon's build thread - Let it begin! Work in Progress XFi EcoModding Central 38 08-01-2008 12:21 AM
