Old 05-09-2014, 04:30 PM   #11 (permalink)
90 day: 51.82 mpg (US)
Sorry, I don't remember exactly.
Old 05-09-2014, 04:49 PM   #12 (permalink)
Not bad for a machine
dirtydave's Avatar
Maechunbu - Retired - '00 Kia Sephia 1.8I4 16VDOHC
Last 3: 45.28 mpg (US)
Slasher - '96 Chevy Corsica 2.2L 3speedauto
Duct Tape Aero Crew
Team Chevy
90 day: 34.76 mpg (US)
Im using an ELM327 OBD2 sensor with Bluetooth to the torque app to an old $10 android phone and when I cut the key back to EOC it loses power and has a delay to reconnect and sometimes doesn't reconnect at all. A kill switch is the best way. It probably loses power to the ECU and the OBD2 port also.
Old 05-09-2014, 05:04 PM   #13 (permalink)
P-hack's Avatar
awesomer - '04 Toyota prius
kill switch should help instead of killing power via the ignition switch. I "think" torque has a setting for using the gps for speed/distance, but the program itself might konk out if you shutdown the adapter, so kill switch.
Old 05-11-2014, 05:00 PM   #14 (permalink)
dirtydave's Avatar
Duct Tape Aero Crew
Team Chevy
Yeah it does and i guess the scangauge does the same thing
Old 07-02-2014, 10:05 AM   #15 (permalink)
Torque apk uses the smartphone gps to measure distances
