Old 11-29-2010, 02:37 PM   #11 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Subaru Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '11 Surly Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
You can calibrate your odometer on the highway. Note the miles to the tenth at the first highway marker you see. Ten miles later, note the miles and tenths on your odometer. Each tenth over a 10 mile stretch is a 1% error. For example, if you car reads 200,000.0 at milepost 140, and 200,010.2 at milepost 150, it's reading 2% high.
Old 11-29-2010, 02:58 PM   #12 (permalink)
Wiki Mod
Weather Spotter's Avatar
Max - '14 Ford C-Max SEL
Originally Posted by Sulfuric View Post
GPS, because every time I turn my engine off with coasting, there is about 1-2 seconds where the ODO does not record any movement. Over a 400 mile tank with heavy P&G I can end up 15 miles off (low) if I trust my ODO instead of GPS.
You need a kill switch, it keeps the dash on while EOC.
Engine kill switch - EcoModder
Old 11-29-2010, 07:34 PM   #13 (permalink)
Sweetie - '11 Hyundai Sonata GLS
90 day: 39.35 mpg (US)
My Miles - '03 Combo GLS/KLX/Ninja
90 day: 40.49 mpg (US)
Sipper' - '04 Kawasaki Ninja 250
90 day: 74.98 mpg (US)
Have not used EOC but neutral coast alot with engine on. Cut the engine at lights if a long one but only during the daylight hours.
Old 01-06-2011, 07:34 PM   #14 (permalink)
Mercedes 89 D - '89 Mercedes 300 E
90 day: 33.86 mpg (US)
Skodie - '09 Skoda Octavia TDI PD
90 day: 38.84 mpg (US)
1993 Mercedes 300D Turbo - '93 Mercedes Benz 300D Turbo W124
90 day: 26.19 mpg (US)
Crossie - '16 Subaru XV Crosstreak
90 day: 9.61 mpg (US)
90 day: 33.34 mpg (US)
Odometer vs GPS
Odometer does take in account climbing slopes, while GPS don´t.
The best way may be to calibrate odometer (or mpguino) in a flat surface with GPS, make a conversion table and then trust odometer.
However, if you want to measure only arc flat distances (kind of X, Y coordinates), GPS is correct and you don´t need corrections or conversions.
If you want to consider "real" miles traveled, odometer is correct as it measures on kind of X, Y, Z coordinates. Remember that we move on a sphere surface. Earth is not flat.
As someone said, they measure different distances. If in good shape, both are approximately correct in their own measures.
Oldbeaver
Old 01-07-2011, 11:08 PM   #15 (permalink)
the crazy guy in back
Cressy - '90 Toyota Cressida
Pickup - '91 Toyota Pickup base
Send a message via AIM to kamesama980
I would imagine it depends on the GPS manufacturer as to whether it accounts for the Z axis as well as X and Y. and what it was intended for. Cheap ones probably do not. expensive ones might. ones meant for off-road use as well most likely.
I go by GPS over odometer. Odometer only has to read within X% from the factory. That's going to be averaged across a few similar but not identical tire sizes at a certain pressure, and in my case I run larger tires at higher pressures in all my cars. I correct the Cressida +15% with the winter tires on: 215/65R16 vs 195/65R15. Take that winter mileage :-D
-2003 Subaru Baja 2.5 5MT
-2005 Subaru Baja 2.5T 5MT
-1994 Pontiac Firebird 5.7 V8/6MT
-2001 BMW R1200c
-1970 VW Beetle
-2015 Prius (for the wife)
"You don't get to blame me for how I fix what you broke."
Old 01-07-2011, 11:27 PM   #16 (permalink)
...beats walking...
..ah, but what *is* the aggregate vertical (Z-axis) error with GPS?
...Answer: a lot more than the latitude and longitudinal X- and Y-axis errors.
...some reading: http://users.erols.com/dlwilson/gpsvert.htm
The Following User Says Thank You to gone-ot For This Useful Post:
oldbeaver (01-09-2011)
Using Google Earth to measure odometer accuracy MetroMPG DIY / How-to 10 07-12-2011 03:38 PM
GPS help Varn Off-Topic Tech 17 11-23-2010 10:31 PM
Checked your odometer, lately? NeilBlanchard DIY / How-to 22 01-01-2010 11:02 PM
Odometer Accuracy for tracking mileage COcyclist Instrumentation 5 12-02-2009 07:22 PM
