Old 08-25-2014, 01:18 AM   #41 (permalink)
Originally Posted by E.Roy View Post
On the transfer case, I believe that a 4x4 tcase will still have the front axle turning, just not the driveshaft, so not much savings IMO over AWD
That's what free-wheel hubs are all about
Old 08-25-2014, 11:26 AM   #42 (permalink)
fuel conserver
Civic - '99 Honda Civic EX
Exactly, I'm happy I have that feature on my '91 Dodge. I believe that makes the u-joints last for decades.
I was just saying on the vehicle this thread is about, a tcase swap might not help FE much if the swap was done just for FE.
'02 E-350 7.3 Diesel (Work Van)
'91.5 Cummins 4x4 (Old Blue)
'00 Jetta TDI 5spd
'22 Tundra TRD OR
'04 RX330
'05 Tacoma 4x4
Old 08-25-2014, 08:14 PM   #43 (permalink)
Swapping just the T-case would still be effective to decrease the fuel consumption, but not so much as it would with some free-wheel hubs fitted to the front axle.
Old 08-25-2014, 10:33 PM   #44 (permalink)
I got ideas
Beast - '97 Mercury Mountaineer
Chillsworld, those Mountaineers and Explorers (especially with the 302) are great quality vehicles. I had a '96 4.0 OHV 2wd 5speed from FL, one of my favorites vehicles I've owned, and changed my mind on Ford. I got up to 24mpg with it. I just told a friend yesterday to let me know if he sells his daughters AWD Mountaineer.
Oh she's an amazing maching, close to 300k miles and other than running hot and having an oil leak... She just scoots along and does whatever I ask of her
You're both right. in 1997 they removed the central disconnect, which means the front is live even if it's got a 4x4 transfer case. I would get better FE due to a lack of parasitic loss when in "RWD", but not the 15-30% I would get if it was a 1996 with the disconnect... Or at least that's what my research has told me. Most people choose to swap in an awd t-case from another ford that has the ability to go 4x4 and 4x4 Lo. They do this so they can keep the electronic AWD but gain the offroad performance of 4x4. Most, if not all swaps I see, are trying to accomplish the opposite of my goals. Somebody like me looking for better FE, isn't the normal guy modifying an Explorer/Mountaineer
~C
I'm really beginning to like eco-humor
Originally Posted by aerohead
PS you could add hamsters inside for a 'bio-hybrid' drive.
Old 08-26-2014, 04:33 AM   #45 (permalink)
Hey, hey—this is the Aerodynamics subforum.
Moon disks!
Old 08-27-2014, 12:18 PM   #46 (permalink)
I got ideas
Saw this on my internet travels..
I don't have the money for that, but a punched body pan???? basically allowing the exhaust and engine air to escape the length of the underbody without disrupting under body flow? The punches are up towards the body and facing the front of the car, not punched down creating more drag. They would be like scoops catching flowing air between the pan and body... Then directing it under the body.
~C
Old 08-27-2014, 04:20 PM   #47 (permalink)
Standard 1940's dry lakes practice. I'd like to see anyone do that with Coroplast.
Old 08-27-2014, 04:36 PM   #48 (permalink)
I got ideas
Is that a challenge?
-C
Old 08-27-2014, 04:52 PM   #49 (permalink)
You can take it for one if you like.
Actually, I'm a Polymetal bigot/booster with contempt for Coroplast. It was an attempt at a take-that zinger.
Old 08-29-2014, 04:09 AM   #50 (permalink)
I'd rather use plywood instead of coroplast for that. I have seen underbody protections made out of plywood in some off-road racing vehicles.
