Old 10-04-2018, 01:13 PM   #1 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Oh, the disappointment ...
... when your car's built-in instrumentation indicates 2.6 kg / 100km
but the fill-up turns out as 3,25 kg / 100km
CNG, so it's weight / distance for me
The Following User Says Thank You to euromodder For This Useful Post:
Ecky (12-23-2018)
Old 10-05-2018, 02:35 AM   #2 (permalink)
That's still not bad.
Though given gasoline is about 0.7kg per liter, not as good, I'd wager, as you get on gasoline?
Old 10-05-2018, 12:50 PM   #3 (permalink)
Permanent Lurker
seifrob's Avatar
Dáčenka - '10 Dacia / Renault Logan MCV 1.5 dCi (X90 k9k)
90 day: 47.08 mpg (US)
Its normal for European car. The MPG readout is always optimistic so average Ruropean consumer feels good. My car (Renault ecu) says i drive for 4.2 l/100 km, whereas my spreadshet says its around 4.8 to 4.9.
Average consumers do not have spreadsheets with tank-to-tank average to check, I suppose.
Old 10-06-2018, 07:51 AM   #4 (permalink)
euromodder's Avatar
I can't choose gasoline
Car only switches to gasoline when the natural gas tanks are completely empty.
Tried it when it was still new, but found it hard to get it under 5 L/100km (over 47 mpg) - that means 200km before running it dry ...
It's tailored to run on CNG.
On gasoline @ 5L/100km, the fuel price would double
Old 10-16-2018, 01:05 PM   #5 (permalink)
euromodder's Avatar
That's better !
2.91 kg/100km which accidentally matches the eco-up's rated CNG consumption
But ... this was done on Low Calorific Value CNG, whereas the up! was officially tested on High Calorific Value CNG that contains about 20% more energy/kg
One of the hypermiling tips is "Join a fuel-economy Forum"
Please add "Rejoin a fuel-economy Forum" to the list
niky (10-16-2018)
Old 12-22-2018, 10:10 AM   #6 (permalink)
MpgUp - '14 VW Eco UP! CNG + Gasoline
90 day: 86.97 mpg (US)
My eco UP! Fis shows about 100 grams too little. I’ve got couple of tanks with 2.2kg calculated but it was 30C heat then. Now with -9C I’m lucky to get 2.9kg
Info about the car: https://gas2.org/2012/12/06/vw-eco-u...or-biomethane/
2014 VW eco UP!
Old 12-25-2018, 12:26 PM   #7 (permalink)
euromodder's Avatar
Mine usually indicates 10% or more too low
With AC, gas consumption is about 0,12 kg/100km higher - but in city driving, AC can double the consumption !
On the up!, you can feel the power it takes off the engine
Copyright ©2000 - 2022, vBulletin Solutions Inc.
