Old 08-13-2021, 02:12 PM   #11 (permalink)
That was a nice floor jack they trashed.
Wonder if that has power steering. instead of this:
I'd have gone with something more like this:
Old 08-22-2021, 04:29 PM   #12 (permalink)
Have you seen how the Schwimmer powered through the water? There was a propeller assembly that swung down over the back and basically hooked in to the crank pulley of the flat-four.
It was not a good boat, but then it was only intended for river crossings and similar small bodies of water. As a car, it was mediocre, and not particularly efficient.
-soD
Old 08-22-2021, 06:07 PM   #13 (permalink)
But what if it was stanced and ran Fuch's?
That rod that is clipped to the top of the muffler was used by a crew member to raise and lower the propeller assembly. A modern Schwimmwagen would have a basalt fiber composite hull that would stop largish caliber rounds, and one or two hydrojets that could be steered and throttled from the driver's seat. It might look like this:
Should've renamed that pic when I squirreled it way. It was some Spanish scooter manufacturer.
The guy that drove an amphibious jeep around the world added a bow piece. A Schwimmwagen with added bow and stern pieces could have the fineness ratio of a U-bloat.
Old 08-24-2021, 08:52 PM   #14 (permalink)
Unless you're talking one of the super stubby U-boats, it would have to be very long bow and stern extensions!!!
Old 08-25-2021, 12:37 AM   #15 (permalink)
Perhaps that was hyperbole?
Another possible approach might be based on this Kubelwagen tank crew trainer. The fake tank tracks could provide flotation and the only entry was through a roof-top hatch. Slow but stable, unless the pontoons were hydroplane profiled on the bottom with retractable wheels.
https://external-content.duckduckgo....jpg&f=1&nofb=1
The pontoons could be articulated, like the 1971 Russian Venus lander's robot Prop-M to lift the Kubelwagen floorpan clear of the water.
cyberneticzoo.com/walking-machines/1971-prop-m-mars-mini-rover-russian/
Would not that be cool?
Old 08-25-2021, 03:16 AM   #16 (permalink)
High Altitude Hybrid
Avalon - '13 Toyota Avalon HV
90 day: 40.45 mpg (US)
Prius - '06 Toyota Prius
The Schwimmwagen was based on 1930's technology. Didn't it have the 25hp engine that was before the 36hp engine? I wonder how one would perform with a 1600cc dual port. Anyhow, I believe it was a pretty good vehicle for it's time. And there're lots of things that can be improved with a little ingenuity on a vehicle like that.
On another note, what about the Sherp?
Old 08-25-2021, 12:33 PM   #17 (permalink)
Compare with the Amphicar. The design changed to an inline four water cooled engine to satisfy the
Coast Guard.
A modern version could be all electric.
Sherps are cool. A good modern example. Those smooth tires struggle to move in the water.
