Old 05-18-2009, 11:32 AM   #1 (permalink)
Ex-lurker
i_am_socket's Avatar
Skeeter - '05 Toyota Corolla LE
90 day: 35.55 mpg (US)
Thumbs up One full year of data
As of this fill-up I have one full year of fuel economy data. Oddly enough, when I put in the numbers into the fuel log for today's fill-up, my FE for the last tank equals my FE for the last year.
How crazy is that? Now I just need to go through my data and see what did where and when so I can do better than last year.
Old 05-19-2009, 04:10 PM   #2 (permalink)
coasting in neutral
Super22LL's Avatar
Georgia - '03 Chevrolet S10 Extended Cab Stepside LS
Last 3: 26.99 mpg (US)
Beth - '07 Yamaha R6S
90 day: 50.74 mpg (US)
Very cool, congrats.
Old 05-20-2009, 04:51 PM   #3 (permalink)
Ex-lurker
After searching through my data, it looks like the biggest threat to my continued good FE is tire pressure. The biggest hits came around getting nails in my tires (and the subsequent under-inflation by the garage).
Also, here's a nifty little graph of the mean temperature of northern NJ vs my average FE by month: (data from here)
Old 07-20-2009, 08:41 PM   #4 (permalink)
Minimal to the maximum
bucknmusky's Avatar
Enola Gay 2.0 - '02 Chevrolet Cavalier Base coupe
90 day: 40.44 mpg (US)
White-tail Hearse - '02 Chevrolet Silverado 1500 LT extended cab
90 day: 15.3 mpg (US)
Because I am a dork (and most of us here are) here is an Idea for you since you are now past the one year mark. If you keep an excell or similar spread sheet for your personal viewing instead of using date format mm-dd-yyyy record your fillups by day of the year such as day #165 for May 14 and every time you change years track it as a new data set so the years run concurrent and you will really begin to notice improvements or decreaces as technique and tuning battle age and wear, other factors such as your temperature graph would then be ruled out as constants. congrats and good luck
ElmScan + Customized Scantool Software = data logging! cfg83 Instrumentation 19 08-08-2010 09:24 PM
New York Auto Show: VW Golf Wins World Car of the Year Award SVOboy EcoModder Blog Discussion 1 12-18-2009 04:46 AM
mods-data-% change or Cd change( installment#5-roofline data) aerohead Aerodynamics 3 09-26-2009 02:01 PM
Weather data, MPGs and ABA Testing. TestDrive EcoModding Central 9 04-28-2009 06:58 PM
Emissions Standards - "Good For Fuel Efficiency," Consumption Data Says trebuchet03 General Efficiency Discussion 11 04-18-2008 01:15 AM
