Old 08-08-2008, 03:29 PM   #21 (permalink)
VX Padawan
VX du Slog - '94 Honda Civic VX
Just want to make sure I have this straight...
This would be an all-in-one unit, leaving me with my RBBB to play with as needed. If I needed to update the code, I'd pop the chip out of the 'guino and set it in my RBBB, programming however I like.
And it'd be hella slick and small.
Is that it? If so, I want one! I like the idea of a kit format that I solder myself... I'm not yet skilled enough for a total DIY, and all those leads intimidate me.
Old 08-08-2008, 03:34 PM   #22 (permalink)
dcb
needs more cowbell
dcb's Avatar
90 day: 96.29 mpg (US)
90 day: 53.56 mpg (US)
Correct, in this scneario you would program your rbbb or iduino or any DIP based duino/clone as "normal" with the latest mpguino code, then swap chips with the guino.
Old 08-19-2008, 07:26 PM   #23 (permalink)
Test Tool Engr.
Red Rocket - '02 Honda Civic LX Sedan
90 day: 33.57 mpg (US)
Bronze Bucket - '98 Toyota Corolla VE
90 day: 34.97 mpg (US)
Silver Bullet - '06 Hyundai Sonata GL
90 day: 31.58 mpg (US)
I didn't notice this thread before, but I was thinking of making an Altoids tin-sized PCB for the OBD MPGuino, and looking at the code for the OBD one and comparing the schematic of the mainline one, there doesn't seem to be much of a reason that both designs can't share a PCB. Maybe we should look into making a unified design and make a volume order? (Personally, the OBD one is very appealing to me, since I have two OBD-II enabled cars...)
Old 08-28-2008, 08:41 AM   #24 (permalink)
7805 Automotive Replacement
Tell you what, Sourcing a 30 volt zener isn't terribly bad, it adds a component, but I cannot believe that there isn't a common 5 volt voltage regulator in existence designed for automotive use. Can somebody mouse around and see if the 7805 should be obsolete for automotive use and replaced with something better?[/QUOTE]
The LM2940.. was designed by National Semiconductor for auto applications with attendent power interruptions and spiking and is available with a 5v output. I'm not sure which temp. spec you're interested in, but in general the T0-220 variety runs just under $2 from DIGI-KEY.
I've watched the development of this project and am ipressed with the progress. Keep up the good work!
G. Taylor
Honda PC800 50mpg
Old 08-28-2008, 09:57 AM   #25 (permalink)
Test Tool Engr.
I'd be more interested in LM2940T because I can easily see the inside of my car being below 0 C
Definitely looks like the right part for the job though. Thanks!
If you're only ordering 1 and need to go Mouser (due to other parts in the order, etc.), they have NTE1951 as a replacement part for LM2940CT.
Old 08-31-2008, 08:31 PM   #26 (permalink)
Wannabe greenie
The Clunker (retired) - '90 Honda Accord EX sedan
90 day: 29.49 mpg (US)
Mountain Goat - '96 Ford Ranger XLT 4x4 SuperCab
90 day: 18 mpg (US)
Zippy - '10 Kymco Agility 125
90 day: 65.03 mpg (US)
Originally Posted by pcrider View Post
G. Taylor
Honda PC800 50mpg
Oh, excellent, a PC rider! I miss my PC terribly, and someday hope to convert one to electric.
Tim
Old 09-22-2008, 06:02 PM   #27 (permalink)
Big Salsa - '04 Toyota Sienna LE
Silver - '10 Toyota Prius III
Has anyone compiled a list of all the parts that are needed for this project? I think a parts list with links to sources would be really handy. If all the parts could be gotten from one source, that would be even better since it saves on shipping. Just a thought.
Old 09-22-2008, 09:39 PM   #28 (permalink)
Ziggy - '95 Audi S6 Sedan
Manfred - '97 Audi A6 Quattro Sedan
90 day: 20.61 mpg (US)
Clarabell - '03 Audi A4 Quattro Avant
Sherman - '98 Audi A6 Quattro Avant
Cab - '96 Audi Cabriolet
Suggestion for Connectors
How about using RJ45 connectors? My Guino is on a breadboard now. To connect to the car, I put an RJ45 jack on the breadboard and found an RJ45 terminator at Lowes for the other end. I made the cable by crimping RJ45 plugs on each end of 8 conductor telephone wire. So I've got 8 wires to work with and a simple way to connect to them elsewhere in the car.
Here's the terminator:
(UPDATE: These connectors are called RJ45 Keystone Jacks. Good price here http://www.monoprice.com/products/su...05&cp_id=10513)
The connector comes with a little plastic punch-down tool. I used it to push 3 solid copper wires into place. In this case, I connect to the wires with alligator clips. It makes a very neat installation.
There are RJ45 jack templates in the Eagle libraries. Jacks can be had for $0.85 at AllElectronics.com.
Old 09-22-2008, 09:55 PM   #29 (permalink)
RJ45 for Onboard Power and for Programming
If a second RJ45 is provided on board it could be used to power the Guino in the car. This cable provides only +12V power and ground.
A programming cable could be built with an RJ45 plug on one end and a USB to TTL serial on the other. It provides +12V power, ground and programming signals. Power and ground fed through the same pins as the onboard power cable.
Remove the onboard power cable from the Guino. Plug in the programming cable. Program the Guino. Swap the cables back. Walla! New code.
If current carrying capacity is an issue, use 2 wires for power and 2 wires for ground. The remaining 4 are available for programming signals.
Old 09-27-2008, 03:24 PM   #30 (permalink)
Red Beast - '82 Honda V45 Sabre Vetter Fairing
90 day: 39.38 mpg (US)
The Wife's bike - '82 Honda CM450E Red
90 day: 57.22 mpg (US)
Yellow Submarine - '04 Dodge Neon SXT
90 day: 28.71 mpg (US)
I am currently using the Iduino for the MPGuino, (I use a telephone cord ($1.99) with a wall mount jack ($0.99) mounted to the car for the quick disconnect.) I would like to re-build my MPGuino in the manner of DCB's prototype board (For neatness) and be able to use the iduino to program the chip if I ever need to.
DCB: Do you have some detailed photos of both sides of your single board prototype? And, couldn't you change the pin settings to make the chip / LCD connection easier? (Yes, I know that this will make it not compatible with the currently constructed 'Guinos and could cause a branch in the software or can possibly be handled with a #define switch)
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
Any interest in developing an open source fuel economy gauge/computer? MetroMPG OpenGauge / MPGuino FE computer 182 06-25-2010 07:00 AM
wheel airdam - deflector - strake? design questions lunarhighway Aerodynamics 14 04-02-2009 12:45 PM
Open Source LEV Controller FrankG Alternative Transportation 1 03-24-2008 03:10 AM
