Old 09-27-2020, 06:19 PM   #11 (permalink)
That is the most awesome article: "Also, the massive wheel arches stiffen the car’s suspension and lower and widen it, increasing the centre of gravity."
That's one to remember!
freebeard (09-27-2020)
Old 09-27-2020, 06:25 PM   #12 (permalink)
I noticed but forget to quote that part. Thanks.
Old 09-27-2020, 09:17 PM   #13 (permalink)
IGL - '04 Saturn Ion
Team Saturn
90 day: 56.19 mpg (US)
I appreciate the input! The main aero benefit I can see coming from the rear panels would be to extend them rearward to break up the large radius of the back of the car for smoother detachment, and the tiny benefit from having wheel skirts in the first place. The front panels would be harder to justify, the only real utilization being that the leading edge could be extended forward to form the inlet of a full height wheel air curtain and possibly some partial skirting of the wheelwell, near the top of the tire
My current Ecotec project...
My last Ecotec project...
Old 09-27-2020, 09:43 PM   #14 (permalink)
マット
M_a_t_t's Avatar
The Van - '95 Chevy Astro Cl V8 Swapped
Team Chevy
90 day: 7.84 mpg (US)
The new bike - '17 Kawasaki Versys X 300 abs
Motorcycle
90 day: 71.94 mpg (US)
The Mercury - '95 Mercury Tracer Trio
Team Ford
90 day: 34.35 mpg (US)
Toyota - '22 Toyota Corolla Hatchback
90 day: 40.11 mpg (US)
Have you heard of separation edges ( https://ecomodder.com/forum/fuel-eco...cations.php#49 ) and wheel arch gap fillers (https://ecomodder.com/forum/fuel-eco...cations.php#39 )?
This appears to be what you are describing.
1973 Fiat 124 Special
1975 Honda Civic CVCC 4spd
1981 Kawasaki KZ750E
1981 Kawasaki KZ650 CSR
1983 Kawasaki KZ1100-A3
1986 Nissan 300zx Turbo 5 spd
1995 Chevy Astro RWD (current project)
1995 Mercury Tracer
2017 Kawasaki VersysX 300
2022 Corolla Hatchback 6MT
https://www.youtube.com/channel/UC6s...LulDUQ8HMj5VKA
Old 09-27-2020, 09:49 PM   #15 (permalink)
Team Saturn
I have separation edges on my bumper but they aren’t full height and aren’t as well designed as I’d like. I could make a gap filler for the front wheelwell (though I could make them more aggressive for the over fenders
Old 09-28-2020, 02:25 AM   #16 (permalink)
Those standard upper separation edges look fine to me! If you haven't already, under the car is where you could achieve much greater gains than with the mods you are describing.
Old 09-28-2020, 02:39 AM   #17 (permalink)
Team Saturn
I added the rear lip from a Saab 9-3 to take advantage of its factory underfloor on the passenger side but I really need to work on my underbody. I used to have a front belly pan and mid pans but they were lost one winter and I haven’t replaced them yet. I had planned to do a splitter/diffuser setup when I’m done working on suspension/powertrain mods, but I might push that forward
Old 09-28-2020, 02:44 AM   #18 (permalink)
Plenty you can do under there... and never use a splitter with a diffuser! (You want air to go under the car, not stop it.)
Old 09-28-2020, 03:07 AM   #19 (permalink)
Team Saturn
I didn’t plan for much other than a ledge protruding out from the bottom of the bumper (an inch or two) to aid in separating the flow that goes over the top of the car, from the air going under it. I used to have a fairly deep air dam but when I switched to the Ion Redline nose I didn’t carry it over. The only other goal for the car (other than low drag and exceptional mileage) is for it to be fairly quick. I drive it really hard from time to time and high speed stability and engine cooling is very important. If I can reduce lift while I’m reducing drag I’m all for it
Old 09-28-2020, 03:23 AM   #20 (permalink)
You want as much air flowing under the smooth underside of the car as possible, and a splitter moves the 'separation line' downwards, ie more air then goes over the top of the car.
Again, you want lots of air under the car. Stopping airflow going under the car is about 30 years out of date!
My road-car Gen 1 Honda Insight develops measured downforce, and that is effective from about 100 km/h (60 mph) upwards. The car does a GPS-measured 200 km/h (124 mph) - and that's on a shortish straight, not max speed. Almost all of the downforce is achieved by working under the car ie undertrays and diffuser.
High-speed stability is best achieved by moving the lateral centre of pressure rearwards, ie rear fins or a rear wing with large endplates.
My Insight:
COcyclist (10-15-2020)
