Old 06-08-2012, 06:58 PM   #1 (permalink)
Volt, gas only - '12 Chevrolet Volt Premium
90 day: 38.02 mpg (US)
Volt, electric only - '12 Chevrolet Volt Premium
90 day: 132.26 mpg (US)
Yukon Denali Hybrid - '12 GMC Yukon Denali Hybrid
90 day: 21.48 mpg (US)
Packing tape grill block
Well i searched for a while on what the prefered method is to block the grill. Dont have time to throw at it for a few more weeks, so i decided to go with clear packing tape. I only did one side and it may be plecebo, but i tjink there was a difference in mileage. Maybe 1 or 2 on the highway. Will do the other side and get pics tomorrow.
Old 06-08-2012, 08:23 PM   #2 (permalink)
Sport Compact Driver
Celica Gts - '84 Toyota Celica Gts
Sports Cars
90 day: 26.32 mpg (US)
The Bee - '96 Mazda B4000 4x4 Base
Pickups
90 day: 20.39 mpg (US)
I dont recomend packing tape. It can be very difficult to remove. Go duct tape, its alot easier to remove and comes in many colors. Lowes and Home Depot sell duct tape that is residue free, it comes off clean.
Old 06-08-2012, 09:39 PM   #3 (permalink)
When i post pictures you'll see why it doesnt matter. Ill most likely end up making it permanent with some fiberglass. My car is beat to hell.
Old 06-09-2012, 12:16 AM   #4 (permalink)
F Truck - '77 Ford F100 2x4, single cab, lwb
90 day: 8.75 mpg (US)
Bombodore - '98 Holden Commodore Exec Wagon
90 day: 21.35 mpg (US)
Civic - '93 Honda Civic GL
90 day: 36.62 mpg (US)
Jim The Prius - '09 Toyota Prius
90 day: 36.66 mpg (US)
i used packing tape for my grill block too, with cardboard over the large open areas of the grill for a little more strength, works well as it conforms to the curves of your bumper a lot better than coroplast or anything else like that, and i could still use my fog lights and the packing tape was clear
(Posted in 2020) 2009 Prius Off Road project: https://ecomodder.com/forum/showthre...ide-38366.html
(Posted in 2012) 1977 F100 Project: http://ecomodder.com/forum/showthrea...tml#post310326
Old 06-09-2012, 01:23 PM   #5 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
The UV in sunlight will eventually break down the plastic and adhesives in the tape and the tape can become brittle in less than 6 months. It's a good test medium but not something I would use as a permanent basis.
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 06-09-2012, 03:06 PM   #6 (permalink)
it's just for testing, makes it really easy to see if it will get too hot. as promised, here are a few pictures, i may have to add a small opening on the top half once i cover the other side, it started to get a little warm yesterday on my way to work, we'll see. right now i have everything blocked except about 4-5 inches on the lower inlet, i chose the lower to leave open because there is an oil cooler on one side and a trans cooler on the driver side.
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
[IMG][/IMG]
I do have a question though, do you think i should add a "louver" at the rear of the rearmost inlet for exhausting air? It looks like that would just allow more air in though.
You can really tell that this bumper cover is almost entirely aesthetic, only about 3-4 inches of the inlet is in front of the radiator.
Old 06-10-2012, 11:22 PM   #7 (permalink)
Finished the other side, hopefully do some testing soon. Unfortunately no aba but if i see more than 40 highway, it'll be an impovement.
Old 06-11-2012, 11:26 AM   #8 (permalink)
Looks good -- is there holes in the chin area ahead of the radiator? If so, you can block them up so that the air that goes in the grill all goes through the radiator; and you might even be able to have smaller openings in the lower grill.
You should add some foam gasket to seal the hood gap, too.
Old 06-13-2012, 01:24 PM   #9 (permalink)
aren't you supposed to get a measured improvement from a grill block? i get nothing, 1mpg if im extra optimistic. i need to check the intake temp, it may be getting too hot with the block.
Old 06-14-2012, 05:30 PM   #10 (permalink)
Sports Cars
Pickups
In my experiance and from what I have read, the grill block is good for about 1/2 an mpg.
Try some coast down tests with it on/off.
