Old 03-08-2011, 04:22 PM   #11 (permalink)
The PRC.
+1 thanks as this is my plan for my MGB - when I get the time.
Old 03-08-2011, 06:26 PM   #12 (permalink)
Smooth Operator
Old Yellar - '79 MGB Tourer Drop-Hood Coupé
Sports Cars
90 day: 25.83 mpg (US)
Old Brown Ford - '91 Ford Bronco Custom
MAGNUM - '05 DODGE MAGNUM SXT
Rustoleum's not very durable ..
all the time on prep work and painting one wants a top coat that will last..
good success has been achieved with foam brushes using automotive paint with a good long pot life,
still lots of sanding to make it smooth ..
Old 03-08-2011, 08:41 PM   #13 (permalink)
n00b.... sortof..
d0sitmatr's Avatar
silver fire - '03 Mazda Protege5
90 day: 32.52 mpg (US)
I disagree, there was a post on utube the guy had painted his car with this method over 4 yrs ago, and the paint still shines. as VT mentioned, its all about the prep work and patience.
~Mike
Old 03-08-2011, 09:15 PM   #14 (permalink)
kindah shame you put the metal patches on the outside of the door if you drilled a hole in the patch , made it so it could pass though the widest part of the hole you and hold it in place by a piece of wood and a woodscrew screwed through the wood on the outside of the door in the little drilled hole couldve stuck it on from the back leave it to dry get the screw out the wood off and skim an extra bit of filler over the big rusthole before sanding it flat with the rest of the sheetmetal
it wouldve made the repair practicly invisible and only be a little more work .
im planning on doing the same thing over here , the only thing is we dont have rustoleum but sumtin by another brandname and ive been told its made different because of european laws i just hope i get the same result
Old 03-08-2011, 09:44 PM   #15 (permalink)
never tried this but looks interesting enough ive often thought you could do this
i think i may try tractor paint
Old 03-09-2011, 01:23 AM   #16 (permalink)
NHRABill's Avatar
Tahoe - '95 Chevrolet Tahoe LT
90 day: 13.22 mpg (US)
SRX - '04 Cadillac SRX AWD
XL - '05 Harley Davidson Sportster XL
90 day: 49.97 mpg (US)
Alero - '02 Oldsmobile Alero GLS
Corvette - '75 Chevrolet Corvette Stingray
Never tried this method but I did Spray my Tahoe on the cheap last summer used the duplicolor paintshop series laquer bought a HVLP gun hooked it to my 33gallon compressor. I cleared it 5 times using a satin technique that I loved at 1st but have grown tired of. it is not a lot of money to do just lots of labor. in the past I did all of the body work and would bring it to Maaco for a $250 paint job and I will probably go that route in the future unless I had a much smaller car the Tahoe is a monster much like that F350.
5 1/2 Quarts of Color 3 quarts of clear
2012 Chevrolet Traverse *active*
2002 Oldsmobile Alero GLS *active*
2002 S10 2wd p/u 139,000mi. *active*
1975 Corvette Stingray *active*
1994 Camaro Z28 Convertible 149k *Sold 2013*
1998 Blazer ZR2 189k *Sold 2012*
1995 Tahoe LT 250k *Sold 2011*
