Old 10-09-2009, 10:36 AM   #51 (permalink)
For us ecomodders, yes. For normal drivers, not a chance. You'll need to monitor your voltage and definitely have an on board charger handy to plug in where you go if there is no sun. Also, long trips will still be a problem unless you can match the power consumption of the car with the panels. On a Metro, since it only pulls a few amps, I think this is doable. For other cars, you'd have to measure and make sure you have enough power generation. Of course, again on cloudy days, this is a problem.
Old 12-30-2009, 03:28 PM   #52 (permalink)
...Two months later!
With the phev install kind of at a standstill for the moment, I took some time to get back to this project.
I've decided to abandon the sunroof idea for now. Its just not going to happen, so I am changing things a bit. I have decided to use the rear window instead. The plus side of it is I have twice the area, so I could get a 60W panel in there. The bad side is I need to park facing north now (not a problem at work). It will still get sun facing the other way, just not as much. I also have to design a retracting system of some sort so I can see while driving, and also it won't collect power while driving. I'd rather have the sunroof, but I just haven't found a good way to get that dot matrix stuff off.
Anyway, I put the panel together today. I was pretty simple, just time consuming. Also, for anyone wanting to do this you need to be VERY careful with the solar cells. Thankfully the ebay seller sent a few extra, but I still broke a few and had to use them.
I found a piece of hardboard in the garage almost the perfect size. My only concern with it is how it'll hold up to the heat. If anyone has any experience with it, please let me know.
This is incredibly easy to do... I actually snapped one completely in half when I went to pick it up on accident.
I didn't have any ribon that they sell on ebay for connecting the cells. So, I just dug around and found some 20 gauge speaker wire. This worked out just fine.
To build the panel, you need to solder the front of one cell to the back of the other. This connects the cells in series to increase the total voltage from the panel. Each cell only generates .5V, so you need quite a few. In the case of a 12V battery charger, you need 36 in series to get 18V. The point being as the load increases on the panel, the voltage across the cells drops some and you need to keep the voltage above the battery voltage to continue charging. Also, on cloudy days there isn't as much voltage created by a cell, so having a higher panel voltage creates a form of buffer to ensure there is still some charging going on in cloudy weather.
Here is the panel all connected together. I still need to attach them somehow to the hardboard. I'll probably just use what others have, a blob of silicon or something similar.
This is what voltage I got on an overcast day, in the house (a sunroom admittedly) off the panel. Not too shabby I don't think. I checked it a bit later and it was producing 13.5V with a bit more sun.
The Following User Says Thank You to Daox For This Useful Post:
MetroMPG (12-30-2009)
Old 12-30-2009, 03:35 PM   #53 (permalink)
90 day: 51.82 mpg (US)
Nice writeup!
Old 12-30-2009, 03:40 PM   #54 (permalink)
Current is limited by the weakest (smallest) cell, right?
I don't know 100% if this would work, but maybe you could "fix" the chipped cells to bring them up to snuff:
If you can figure out how to cut or break the cells straight, you could use that left over chipped one, split it and then split off the chipped portion of the cell you used. Parallel the two unchipped halves and then put them back in series.
You might have enough left over to do the other chipped one.
Old 12-30-2009, 05:35 PM   #55 (permalink)
Matt Herring's Avatar
Bone's 2010 Prius - '10 Toyota Prius Black
90 day: 56.78 mpg (US)
Nice work Tim...Great projects you have going for the Prius this winter!
Old 12-30-2009, 06:38 PM   #56 (permalink)
Ya must have misread, this is for my Paseo.
Old 12-30-2009, 06:41 PM   #57 (permalink)
Ahhh...my bad. I'm one of those speed readers...with no retention! Still cool projects you have going and looking forward to seeing the results...best of luck!
Old 12-30-2009, 06:47 PM   #58 (permalink)
If it works nice on the Paseo the Prius probably isn't far behind though.
Old 12-30-2009, 07:03 PM   #59 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I'd like to see a solar roof on the Prius... To show up Toyota and their solar sunroof.
Old 12-30-2009, 07:14 PM   #60 (permalink)
The work continues. I pained the hardboard this afternoon. Grey on one side to match the interior and white on the other side to help keep the cells cool (cooler cells means more power generated) and keep heat out of the car in summer.
Its starting to look halfway decent.
Replacing alternator with solar panel array on roof? blackjackel EcoModding Central 91 01-19-2012 09:19 PM
DIY Car Solar Roof SVOboy EcoModder Blog Discussion 1 08-14-2009 03:31 PM
xB Solar panel roof trikkonceptz EcoModding Central 10 02-28-2009 03:27 PM
Solar cell panel on the roof..?. Xringer EcoModding Central 5 09-07-2008 01:51 AM
