Old 12-11-2009, 11:37 AM   #141 (permalink)
PaulH
MPaulHolmes's Avatar
Wow, Thank you!
I've been patiently waiting for my dang isolation transformer before I start the major hardware side. I bought it on Ebay Nov. 10, and it's not here yet.
kits and boards
Old 12-11-2009, 03:37 PM   #142 (permalink)
jackbauer's Avatar
hey paul any sign of those igbts?
Old 12-11-2009, 03:45 PM   #143 (permalink)
PaulH
not yet... boohooo!
kits and boards
Old 12-11-2009, 04:58 PM   #144 (permalink)
AC-DC enthusiast
mrbigh's Avatar
Dual-PWR PHEV - '04 Toyota Prius
Kopper - '79 Bradley Bradley GT-II
Originally Posted by MPaulHolmes View Post
Wow, Thank you!
It may be sightseen by transformer land............
Old 12-14-2009, 02:48 PM   #145 (permalink)
I now have a Solectria ACgtx20 motor sitting in the living room! The controller and full controller schematics will be making their appearance hopefully soon, but this sucker is going to need a proper, beefy controller. The UMOC controllers it was built with are extremely buggy, and apparently low power compared to what the motor can give.
It does have an encoder on it, but I don't have the pin outs for it yet.
I did a quick glance at the C coding that Microchip has, and I don't know what was scarier, the fact that I these Solectria parts, or that fact that I understood most of the coding. I guess my C++ class this semester has paid off.....
Civic EV http://2001-civic-ev.blogspot.com/
Solectria Force http://solectriaforce.blogspot.com/
Old 12-14-2009, 03:34 PM   #146 (permalink)
PaulH
Can you take a picture of the encoder? That's perfect.
kits and boards
Old 12-14-2009, 03:43 PM   #147 (permalink)
On it.....
Old 12-14-2009, 04:05 PM   #148 (permalink)
Well, my encoder is not wanting to come apart, but I have found a supply of pictures that work. ACgtx20 Motor Encoder Repair
I am hoping to be getting the full schematics soon and the Encoder has all grey wires so I have no idea what they do. I got the low down today on how the Solectria controllers function, being MOSFET based makes it quite interesting. It's mainly because the Solectria systems are 144 volts, not really high voltage, but they only used 200 volt fets and bust when the regen activates and the battery pack is full, then ringing pushes the voltage over 230 volts and pop goes the FETs. The newer DMOC controllers has solved that issue.
Old 12-14-2009, 05:02 PM   #149 (permalink)
EVVette - '71 Chevy Corvette Coupe
How about a picture of the whole motor?? How big is it?
-Adam
www.EVVette.com - 1971 Corvette Coupe Conversion to all Electric!
www.AdamBrunette.com - Machining, CNC, Robotics and Electronics.
You can download RTD Explorer for the Cougar controllers at www.EVVette.com
Old 12-14-2009, 05:50 PM   #150 (permalink)
It's 11 inches long and have a 10" diameter front plate.
ACgtx20 Specs:
12 KW Nominal
42 KW Peak
70NM torque peak
4,000 RPM Nominal
12,000 RPM peak
It's tiny compared to my FB1-4001A, but basically more powerful than my 96 volt DC setup.
I have no plans to put this in my Civic, but I am planning another EV, probably for 2011 so might as well get started now on the planning. I am thinking of using a 2002 Ford Escape, or Mazda Tribute. I am looking for a small SUV for the wintery drives and planning to save up over the months. I am estimating only $1800 for the EV hardware, excluding the batteries and the actual donor. And it's going to be a 156 volt LiFePO4 system, so I need to do a lot of saving up.
Paul & Sabrina's cheap DIY 144v motor controller MPaulHolmes Open ReVolt: open source DC motor controller 7381 08-02-2023 10:55 PM
Contest! Name Paul & Sabrina's controller MetroMPG Forum News & Feedback 120 10-22-2011 01:59 PM
