Old 01-05-2012, 06:40 PM   #5381 (permalink)
No, just when the throttle is pressed
Old 01-05-2012, 06:52 PM   #5382 (permalink)
PaulH
MPaulHolmes's Avatar
OK, then the pwm isn't making it from the microcontroller to the output of the driver. We just need to backtrack until we find where it's not making it. It's then probably just a bad solder joint or something. OK! Now, check the voltage across R16. One probe on one side of R16, and the other on the other side of R16, at zero throttle and at some nonzero throttle.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
Ken6881 (01-06-2012)
Old 01-05-2012, 06:56 PM   #5383 (permalink)
there is no voltage across r16 at any time ( i did check my voltmeter to ensure it was working)
Old 01-05-2012, 08:04 PM   #5384 (permalink)
PaulH
OK, so the mosfet driver is probably fine. The next culprit to check out is the HCPL-4504 optocoupler. Check opposite sides of R15 at zero and full throttle.
kits and boards
Old 01-05-2012, 08:25 PM   #5385 (permalink)
it is also zero at all times
for fun i went ahead and checked r14 and it is .88v at all times
Old 01-06-2012, 01:33 AM   #5386 (permalink)
PaulH
Try it with R12.
kits and boards
Old 01-06-2012, 07:49 AM   #5387 (permalink)
0v at zero throttle and 4.5v at full for R12
Old 01-06-2012, 08:06 AM   #5388 (permalink)
Golfwagen - '89 Volkswagen Golf mk2
90 day: 107.14 mpg (US)
Is your controller connected to a motor? If yes, how? (I mean which wire goes where).
Old 01-06-2012, 08:51 AM   #5389 (permalink)
PaulH
Well good! the PWM is working!! What's Pin 2, 6, 9, or 13 doing of the NAND (U5)? They should all be connected together, so I guess you could check that the resistance from one of those 4 pins to another is almost zero. I'd check ALL the solder joints connected in any way to U5, because I think that's where the problem is.
kits and boards
Old 01-06-2012, 05:54 PM   #5390 (permalink)
That was it, resoldered U5 pins and tested PH1 and PH2 to GR 1-10, got voltages. Then reconnected to pack, precharged, closed contactor. Controls motor! Thanks Paul!
The Following User Says Thank You to Ken6881 For This Useful Post:
MPaulHolmes (01-06-2012)
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3480 05-04-2022 05:43 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 04:10 PM
