Old 08-07-2014, 09:01 AM   #6791 (permalink)
PaulH
MPaulHolmes's Avatar
Oops, I forgot. I also don't know what any of the stuff is that you wrote in the last comment. But I'm sure its a good idea. So, YES. Make one of those things that you just said. Haha.
kits and boards
Old 08-07-2014, 09:02 AM   #6792 (permalink)
EV Connoisseur
I was referring to this:
Originally Posted by flores View Post
Paul,
Is it possible to create a 'rtd' command, that would spit out one line of rtd data on request? in addition to the rtd-period.
I'm having a hard time with the continuous stream of data on the raspberry a.t.m. and such a command would help me a lot.
thanks.
Old 08-07-2014, 09:03 AM   #6793 (permalink)
EV Connoisseur
Oh .. I get it.. github.. it is a source code repository thing..
Old 08-07-2014, 09:04 AM   #6794 (permalink)
EV Connoisseur
And that would only work if everybody that works on the firmware actually uses it.. that means you have to use it primarily
Old 08-07-2014, 09:27 AM   #6795 (permalink)
PaulH
Is it 'stab yourself in the eyeball' irritating like Turtle SVN?
kits and boards
Old 08-07-2014, 09:29 AM   #6796 (permalink)
EV Connoisseur
No.. that's why they created it..
The Following User Says Thank You to flores For This Useful Post:
MPaulHolmes (08-07-2014)
Old 08-07-2014, 09:54 AM   #6797 (permalink)
PaulH
Well, I think that would be fine then. I just finished the changes for a new command that gives a single stream and then stops. The command is ...
rtd
Boy that was dramatic. I'll email you the code/hex file.
kits and boards
The Following User Says Thank You to MPaulHolmes For This Useful Post:
flores (08-07-2014)
Old 08-07-2014, 10:01 AM   #6798 (permalink)
EV Connoisseur
Thanx!
Old 08-07-2014, 12:51 PM   #6799 (permalink)
PaulH
For anyone wanting to convert their 0-5k PB-6 throttle to hall effect, you can just take the original pot out and put this in:
http://www.digikey.com/scripts/DkSea...30055978148584
kits and boards
flores (08-08-2014)
Old 08-07-2014, 01:20 PM   #6800 (permalink)
PLUGnGO
jedsmd's Avatar
Invalid Request
Paul that link gets a 404. Could you fix it or give some search key words
Paul and Sabrina's Cheap 3 Phase Inverter (AC Controller) with Field Oriented Control MPaulHolmes Fossil Fuel Free 3431 05-04-2022 06:43 PM
Paul & Sabrina's Cheap EV Conversion MPaulHolmes Fossil Fuel Free 542 11-12-2016 10:09 PM
Three Dirt Cheap DIY Electric Cars - Part 5 SVOboy EcoModder Blog Discussion 0 12-12-2008 05:10 PM
