The C-119 had a gradual curve to the body though. Take a look at this plane : The IAI Arava . ![]() ![]() It sure would be nice to have attached flow with a tail that short ! |
#2 (permalink) |
Woody - '96 Dodge Ram 2500 SLT Team Cummins 90 day: 23.82 mpg (US) Avion and Woody - '96 Dodge/Avion Ram 2500/5th wheel combo 90 day: 15.1 mpg (US) TD eye eye eye - '03 Volkswagen Beetle GLS 90 day: 49.05 mpg (US) Mule - '07 Dodge Ram 3500 ST Thanks: 743
I'm sure that somewhere out there are some performance charts in operation manuals that tell you how well or badly it performed with the tail off.
#3 (permalink) |
Drag increased significantly on both, and all similar designs, when the rear clamshell doors were removed.
This resulted in more power and fuel required, less range, more buffeting, lack of pressurisation in transit - i.e. lower transit height, cutting down range even further. It was also extra work to remove or refit the doors, and that work needed to be done before the actual transport job - the clamshell doors couldn't be opened in flight. The ultimate result was the disappearance of such designs in favor of the rear loading ramp design on all modern tactical and practical transports C-123, C-130, C141, C-5, C-17, C-27, C-235, C-295, A-400M and all their CCCP counterparts. |
#4 (permalink) |
22-23
Between Mair and Buchheim the limit for attached flow will lie around 22-23 degrees of tangent angle.Anything beyond that and we'll have separation unless we provide blowing or vacuum in critical areas.
These 'steep' curvatures may have been a compromise for the life-cycle-cost analysis of the particular project. If you have Kate Winslet in the can,you might get some extra $millions re-releasing her films in 3-D.Or is that Double-D? If you' re hauling freight and 115/145 AVGAS is costing you 18-cents a gallon as when I used to pump it,you may not give a d--- about a little extra drag and a mediocre boat tail.I wouldn't try and read too much into 'why' certain things got done unless you have access to the designer. And with respect to the Packet and Flying Boxcar,a number of parachutists were injured attempting to jump with the tail in place,so they just removed it and lived with the inefficiency. ![]() |
#5 (permalink) |
airplanes operate at higher speeds then our cars - higher speeds imply different reynolds numbers which means they get to use different degrees of taper.
An example - airplane wings "stall" if you go too slow. |
#6 (permalink) |
I can tell you that these designs of aircraft are far from ideal and that there is probably separated flow on them towards the point. You would have to look at the local Reynolds number and put them in a tunnel to see. I would guess that flow around them is far from perfect, especially with the state of aero research then.
You can tell a lot about an aircraft by looking at it closely. On some aircraft, you can see where the flow is expected to become turbulent by the rivets. Laminar flow has smooth rivets due to the thinness of the boundary layer but after the switch the structure will use stronger and cheaper raised rivets because they still reside within the boundary layer and have almost no effect on drag. Generally lower speeds mean more attached flow at a receding surface. Also, you can think of detached flow at a rear window of a car almost exactly the same as a stall. In both cases the flow detaches from the surface and drag increases significantly. Except the car doesn't loose lift and fall out of the sky.
![]() ![]() Civic Build Thread Your grammar is appreciated. 3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires |
#7 (permalink) | |
Rat Racer
It's not the rear end of an airplane, anyway. It's a cargo loading door. Any thought given to aero was with an eye to not interfering with loading and unloading. The overall feeling here shouldn't be "that's not really good aero," it should be "Wow! it even flies!" ![]() ![]() ![]() |
#8 (permalink) |
PSmodder lurker
Reminds me of my favorite 'aerodynamics lesson' movie of all time! (Not the 2004 remake, though still OK) Who's a Heinrich Dorfmann on Ecomodder.com?
Unfortunately, the movie's stunt pilots really suffered what everyone thought would happen. Last edited by botsapper; 05-14-2012 at 12:02 PM.. |
#9 (permalink) | |
get to use
If air,or any 'fluid' is attacking a particular curve,of any given radius,if 'zero' is the forward stagnation point,the 'fluid' MUST separate at 115-degrees of rotation beyond the stagnation point. Example: if an analog wristwatch is moving from right to left,and the air first strikes at the 9:00 position,the air will not be able to remain attached beyond 4-seconds after 12:00.By the way,the angle at the separation point is 22-degrees. |
#10 (permalink) | |
Where does Reynolds Number fit in with what you are saying? Are you implying that all objects with all reynolds numbers all stall at about 22 degrees normal to the surface? Surely that is not what you are saying???? |
