Old 03-14-2011, 04:00 PM   #11 (permalink)
Originally Posted by UFO View Post
I'm very surprised the petrol gets mileage almost as good as the diesel.
Ditto. Do you have a website to compare ACTUAL user data vs just the government testing? That might show more accurate real world data.
Old 03-14-2011, 04:46 PM   #12 (permalink)
The PRC.
I would love to find some real-world comparison data to use. I know from experience of UK official MPG that Diesels tend to get closer to the official figures in the real world and petrols struggle, even hybrids.
Perusing owners forums and owners reviews on places like Autotrader suggest Petrol owners struggle hard to get under 50 MPG averages. Diesel owners are thinner on the ground but some claim over 70.
Old 03-15-2011, 03:37 AM   #13 (permalink)
aero guerrilla
Piwoslaw's Avatar
90 day: 58.1 mpg (US)
If this car will be for short trips only, then go with petrol because of warm-up time.
Modern turbodiesels are so complicated, plus PSA doesn't allow more than 30% biodiesel.
A petrol is probably better suited for killing the engine.
I think the reason the petrol gets almost as good mpg's is weight: a diesel engine is usually heavier then a gasser of the same size, and here the HDi is 40% larger.
The Following User Says Thank You to Piwoslaw For This Useful Post:
Arragonis (03-15-2011)
Old 03-15-2011, 03:55 AM   #14 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Arragonis View Post
You can make your own but I haven't seen a pump with B100. All Diesel here is 5% Biodiesel.
We don't usually have B100 (nor PPO) pumps either, though apparently you can buy it here and there from manufacturers.
B100 is widely available in Germany though.
Not sure if the HDi is Biodiesel friendly.
Not when equipped with a DPF.
According to PSA, it's B30 max - and then only if you halve the oil changes interval.
The Following User Says Thank You to euromodder For This Useful Post:
Old 03-15-2011, 04:07 AM   #15 (permalink)
euromodder's Avatar
Some of the latest small (i.e. Aygo sized) petrol cars get above 50 mpg (US) as well.
Obviously those are the official EU figures.
Matching those isn't going to be easy.
Real world numbers by searching here :
Advanced search - Spritmonitor.de
Plenty of Citroen C1 petrol owners beat the figures.
Aygo owners seem to have a harder time.
Old 03-15-2011, 04:08 AM   #16 (permalink)
The PRC.
Thats my thoughts exactly. I need to get into a decent test drive to check out whether the hills issue is a killer for the Petrol. I don't mind going slower but I do mind having to stir pudding all the time.
Thanks for the B100 info. You can buy it here too, 90p a litre compared to 136 for 5% at the pumps. But outlets are not convenient.
Old 03-15-2011, 04:17 AM   #17 (permalink)
The PRC.
Aha. Looking at the most common figure for the C1 Petrol it comes out at 54, the Diesel at 65 (fewer figures though) which is a sizeable difference. Buying new that would take quite a few miles to make up the difference in price but there seems to be no Diesel premium on used and there are no new ones anyway.
Add a block heater and the warm up issue goes ?
More pondering.
On the other side Mrs A may be offered the possibility of a company Hybrid, Auris or Prius.
Old 03-16-2011, 05:04 PM   #18 (permalink)
fidalgoman's Avatar
I as well prefer the diesel. One major issue is local availability. It is true that diesel trucks will be running even if the cars don't should there be a shortage of fuel, but that doesn't mean you'll be able to buy any. Considering the small MPG difference I'd buy whatever is more common (if it's a huge availability difference).
Old 03-16-2011, 06:05 PM   #19 (permalink)
euromodder's Avatar
The best of them are getting very comparable fuel consumption.
It speeds upthe warming, but won't make it go away.
Can you plug it in when you're away from home ?
If not, that halves the benefit.
My 1.6D is only warmed up after around 6 miles.
Old 03-16-2011, 07:49 PM   #20 (permalink)
The Mistress - '88 Bmw 320i Touring SE
Team m8
Last 3: 27.17 mpg (US)
Germany Beadle - '91 Mercedes 300td (estate, N/A)
90 day: 24.63 mpg (US)
The Bloodylingo - '05 Citroen Berlingo Multispace Desire
90 day: 39.77 mpg (US)
Shanner Scaab - '03 Saab 9-5 estate Vector
90 day: 26.19 mpg (US)
Clio 182 - '05 Renault Clio RS 182 182
90 day: 31.73 mpg (US)
£800 got a W plate Lupo 1.0 MPI petrol from the auctions I was at today..
Thats gotta be a WIN above any PSA rubbish? or they did a 1.4 diesel..
