Old 04-29-2012, 10:08 PM   #11 (permalink)
Pc3 - '12 Toyota Prius c 3
90 day: 49.3 mpg (US)
Daox, done. 60.2mpg over same trip today. I realize the display is likely optomistic, but on the same trip I can generalize.
All the best.
The Following User Says Thank You to graesack For This Useful Post:
Daox (04-30-2012)
Old 04-29-2012, 10:17 PM   #12 (permalink)
By the way, the general consensus is that an upper grill block is the place to start, and then add a partial lower gill block if possible.
Old 04-30-2012, 09:56 AM   #13 (permalink)
Neil, I understand from diagrams that the converter cooler on the Pc is at the top of the radiator. Others, it's at the bottom. I didn't want to cut air flow to it.
All the best,
Graeme
Old 04-30-2012, 01:07 PM   #14 (permalink)
60mpg real world is impressive to say the least. Can somebody please take a pic of the trunk with the foam blocks and spare tire removed? I'm curious to see how much trunk space it has without the dead weight.
thanks
Old 04-30-2012, 01:13 PM   #15 (permalink)
All the best,
Graeme
I have had the lower grill entirely blocked on my 04 for a couple years now. I haven't had any issues and I have a PHEV kit so I use the electric motors a lot more than the normal Prius driver. I wouldn't worry about cutting airflow to it.
Old 04-30-2012, 03:03 PM   #16 (permalink)
Daox, good to know. I'm a little gun shy with a two-day old car.
All the best,
Graeme
Old 04-30-2012, 03:18 PM   #17 (permalink)
Pokémoderator
cfg83's Avatar
Team Saturn
90 day: 40.49 mpg (US)
graesack -
All the best,
Graeme
It's better to establish a "no mod" baseline anyway. If I were you all my mods would be reversible until the warranty ran out.
CarloSW2
American Solar Energy Society
The Following User Says Thank You to cfg83 For This Useful Post:
graesack (04-30-2012)
Old 05-03-2012, 01:31 PM   #18 (permalink)
Easter McoModder
SwamiSalami's Avatar
'99 Subaru OLL 2.5L - '99 Subaru Outback Legacy Limited
90 day: 22.57 mpg (US)
Rabbit - '08 VW Rabbit S
90 day: 32.93 mpg (US)
Lower grille block and SG in today.
All the best.
where are you ordering this stuff from?
also, what speed transmission is this thing?
thanks
Old 05-03-2012, 02:02 PM   #19 (permalink)
All hybrid synergy drive vehicles (ford and toyota) have CVT type transmissions that are nothing like conventional CVT transmissions. Its basically a planetary gearbox with two electric motors and the engine all on different inputs.
The Following 2 Users Say Thank You to Daox For This Useful Post:
graesack (05-03-2012), SwamiSalami (05-04-2012)
Old 05-03-2012, 03:09 PM   #20 (permalink)
Grille block is just 1/2" foam pipe insulation wedged in the grille opening. Slits cut in back of foam to clear vertical portions of the grille. ScanGauge I've had for years. I just got it back from being updated.
As answered previously, the transmission is a planetary CVT.
All the best.
prius c, prius c aerodynamics
