Old 06-23-2009, 10:49 AM   #1 (permalink)
Sharon - '00 Fiat Punto ELX JTD
90 day: 42.76 mpg (US)
Pizza pan wheel covers - smooth or perforated?
I'm going to buy a set of pizza baking pans as wheelcovers and I have a dillema.
On one hand there are smooth pans which are a perfect aero choice - proven and nice looking.
On the other hand there are perforated pans - easy to mount with zip ties and probably allowing better brake ventillation.
Any help choosing?
Old 06-23-2009, 10:58 AM   #2 (permalink)
90 day: 51.82 mpg (US)
Smooth is smoother.
Brake cooling has to be taken into account though. Most ecodrivers don't use their brakes hard/long enough for it to be an issue though.
If you live in mountainous terrain, that may be unavoidable.
Old 06-23-2009, 06:14 PM   #3 (permalink)
Driving the TurboWeasel
Your brakes should get adequate ventilation from the inside edge of the wheel, I'd think. Ask around, it may be I'm totally wrong.
Next time you do brakes get ceramic pads along with drilled rotors. Heat will not be as big an issue then.
2012 Chevrolet Cruze Eco 6MT
Old 06-23-2009, 06:47 PM   #4 (permalink)
single perf
Jabb,a sweet compromise,is a single opening which allows access to the valve stem and also vents braking air.An image of such a setup is from the Renault Vesta-II,146-mpg concept.The image is in "Other vehicles 1, page -1,line-1,second photo, @------------------------------------------------------- Fuel Economy, Hypermiling, EcoModding News and Forum - EcoModder.com - aerohead's Album: Other vehicles 1 - Picture
Old 06-23-2009, 08:41 PM   #5 (permalink)
Seems like it would be better to have a hole on the opposite side too, to balance the forces and let a little more air in
Old 06-23-2009, 09:01 PM   #6 (permalink)
Things are not always what they seem.
Really, if you are a semi-decent ecodriver, and unless like Metro said, you're going down a mountain, you are not going to overheat your brakes.
Experiment: smooth wheel discs tested A-B-A - 4.6% mpg improvement @ 65 mph Concrete Aerodynamics 318 01-19-2015 11:37 AM
Rear Wheel Skirt using water heater drain pan cfg83 Aerodynamics 45 02-20-2012 02:08 AM
Smooth wheel covers on latest Ferarri F1 race car? MetroMPG Aerodynamics 14 05-16-2009 01:48 AM
Cheap-o Smooth Wheel Covers bennelson Aerodynamics 40 03-15-2009 11:55 PM
Modded wheel covers to make them smooth MetroMPG Aerodynamics 1 11-27-2007 08:43 PM
