Old 01-16-2010, 01:09 AM   #1 (permalink)
Tank - '76 Chevy El Camino Classic
90 day: 25.89 mpg (US)
Sabrina - '91 Mercedes Benz 190 E
90 day: 37.07 mpg (US)
Angel - '88 Mercedes-Benz 420SEL
Last 3: 23.01 mpg (US)
Quicksilver - '04 Mercedes-Benz CLK55 AMG Cabrio
Plans for grille block on Tank
I'm planning on doing an upper grille block on my el camino to see if it improves mileage at all
Should I try it on the inside or the outside?
Here's a pic
and what should i use? it HAS to be black
Tank:
(No actual EPA numbers for car just used F/E numbers when i first got it)
Old 01-16-2010, 01:04 PM   #2 (permalink)
Looks like a good candidate for a clear plastic cover on the outside.
The Following User Says Thank You to winkosmosis For This Useful Post:
Domman56 (01-16-2010)
Old 01-16-2010, 10:48 PM   #3 (permalink)
ecomonkey
silver clown - '02 toyota echo 2 door base
90 day: 47.16 mpg (US)
white ghost - '05 prius base
90 day: 47.53 mpg (US)
white pearl - '12 toyota prius base
Last 3: 45.69 mpg (US)
that grill is huge,, i guess its only got 1 big one, instead of the more modern upper and lower. hope you have a good temp gauge or scangage to watch temps. since most of your cooling comes thru the one big opening are you going to do all the way accross at top /bottom ,or leave a gap in the middle.id do it with something cheap like cardboard/garbage bag/ducttape until i found out how much i could permanatly cover, then clear lexan,or paint it if you want. but you should see a noticeable difference with that huge hole partialy blocked.
The Following User Says Thank You to moonmonkey For This Useful Post:
Domman56 (01-17-2010)
Old 01-17-2010, 12:53 AM   #4 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
Before you block the grille, make sure you seal up the radiator. Any air that is still able to get through the grille, you want it going through the radiator, as opposed to around it.
After that, just start making black strips about 2-3" wide and as tall as your grille, and fasten them to the inside so you can't really see them, starting from the outside and working your way in until you're comfortable with what you have.
Once you seal your radiator, you could probably easily block 30% of your grille and not even notice a difference in temps.
Old 01-17-2010, 12:24 PM   #5 (permalink)
THank man i think i'm gonna start on blocking the upper half of the grille but what should i use for the strips on the inside?
Tank:
Old 01-17-2010, 01:17 PM   #6 (permalink)
you could start with painted cardboard on the inside, from soda/beer boxes.
I only say to start on the inside because that way, if you don't end up blocking a large section of it, or you don't like the way it looks/functions, you won't have spent alot of time on making it work right on the outside.
Old 01-20-2010, 12:40 AM   #7 (permalink)
Getting BETTER Mileage
Jethro's Avatar
Lucky No 19 - '11 Ram 1500 Express ST
Venti - '13 Ram 2500 Tradesman
Any area that is not directly infront of the radiator should be able to be blocked off without any ill effects on cooling. Even at that, I'm sure you can block off more and create 'flow directors' of sorts, basically, make sure the air flowing IN the grill it going through the radiator and not just blowing around violently.
Ya know, since the rest of the car is soooo aero. (Mind you, I have a '00 Ram Truck)
- Greg
101.5 MPG on my 2003 Ninja 250!!! theycallmeebryan Motorcycles / Scooters 308 01-06-2016 01:56 AM
1.5 L Toyota block heater bwilson4web Hybrids 11 12-24-2009 01:30 PM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
Hole in gas tank mrmad EcoModding Central 5 03-18-2009 04:33 PM
Smaller Fuel Tank steensn EcoModding Central 5 07-11-2008 01:09 PM
