Old 10-03-2008, 08:58 AM   #11 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
I think it's critical to the numbers I get. I'm never in gear except for a pulse here and there. It's hard to quantify the gain from this alone, but the overall P&G, including the coasting, is easily worth 15mpg of my 60. I've found in-gear "coasting" to be a net loss, except down mountains. Pulse & DFCO is about the same as or even worse than gentle steady speed.
I don't consider DFCO to be coasting. It's very much engine braking.
The Following User Says Thank You to PaleMelanesian For This Useful Post:
j12piprius (02-28-2011)
Old 10-08-2008, 12:09 PM   #12 (permalink)
Pipina - '93 Honda Civic CX
90 day: 46.88 mpg (US)
if i engine brake in my 93 civic dx will it burn fuel?
Old 10-08-2008, 12:51 PM   #13 (permalink)
wagonman76's Avatar
Red Car - '89 Chevrolet Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 Pontiac 6000 LE Wagon
90 day: 28.26 mpg (US)
Well, you can't be using no
I've read a few times when people get instant fuel consumption displays how surprised they are at how relatively minor throttle position changes can have relatively big MPG changes.
Yes thats one of the first things I noticed with my mpguino. I can pull back the throttle just a split hair and maintain the same speed but get noticeably better mpg. Maybe it is reducing the load enough to advance the timing and get the added power to keep going. This might be the sweet spot that ac7ss is talking about.
I POC a lot, because I can get double to triple my mpg when doing so, or get infinite mpg with the fuel cut. Sometimes I can also hold the throttle just at the right spot to keep the TCC locked and keep the fuel cut all the way down the hill without losing the speed of a regular POC. Id usually rather POC than go to N, since it is very quick to get back to power again. In my car if I went to N and back to D at anything over 30 mph, the trans would be hunting for like 5 seconds and losing speed and mpg.
Winter daily driver, parked most days right now
Summer daily driver
coasting, poc
Saturn S-Series 5th Gear Swap cfg83 EcoModding Central 61 05-02-2012 09:31 PM
Coasting in gear vs. neutral (fuel cut feature) WTFM8 Hypermiling / EcoDriver's Ed 28 05-29-2011 10:39 AM
Does coasting in neutral or coasting in gear save more gas? xbUser Hypermiling / EcoDriver's Ed 19 10-19-2008 01:28 PM
Out of gear coasting safety tasdrouille Hypermiling / EcoDriver's Ed 42 09-25-2008 07:18 PM
Coasting in Neutral Vs. Coasting in Drive observation fonque Hypermiling / EcoDriver's Ed 21 07-17-2008 03:49 PM
