Old 05-23-2008, 10:36 PM   #1 (permalink)
EcoModder Newb
Blue Car - '05 Honda Civic Hybrid
Question 2005 Civic Hybrid Instruments?
I was just wondering what the accuracy of the stock instruments is like? How does it gather the MPG? Would a scanguage benefit me and if so how? I'm sure there will be more questions. Thanks for any input.
Old 05-24-2008, 09:28 AM   #2 (permalink)
I hear the stock mpg gauge is fairly accurate (usually within 2 mpg). I'm not sure how it gathers its readings exactly. A scangauge will still be of benefit as it can monitor a lot of other things.
Old 06-01-2008, 10:10 PM   #3 (permalink)
Enthusiast Kinda
2005 HCH - '05 Honda Civic Hybrid XL
90 day: 46.19 mpg (US)
Send a message via MSN to MasterAlex
I know that it calculates how much gas has been used every 1/10th of a mile. I'm pretty sure it just takes how many miles you've gone and then divides that by the gallons of gas used.
I know this is probably in other threads, but while I'm at it, how much do scan gauges cost and where can I get one?
Old 06-01-2008, 10:56 PM   #4 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Honda Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Surly Big Dummy
Send a message via AIM to AndrewJ
This thread has all the info about how to get one, how much and all that jazz.
Also, if you like DIY type stuff, or the scangauge proves too expensive, keep the MPGuino in mind.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Lower Grill Block 2005 Honda Civic Arminius EcoModding Central 12 10-04-2011 12:31 AM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Pick Your Poison - Whose gas to buy? SVOboy General Efficiency Discussion 84 11-22-2010 10:19 PM
Air Dam and Tray (2005 Civic Sedan) Harpo Aerodynamics 14 10-27-2008 12:56 PM
2005 Civic Upper Grill Block Harpo Aerodynamics 13 03-17-2008 11:55 AM
