Old 07-17-2015, 08:54 AM   #11 (permalink)
Joggernot's Avatar
My coasting distance in the Accord increased considerably when I replaced the rear wheel bearings. Apparently they were going out and I hadn't noticed. Started arriving at the stop signs and lights going much faster than I normally did before the replacements.
The Following User Says Thank You to Joggernot For This Useful Post:
RPM (07-17-2015)
Old 07-18-2015, 12:59 AM   #12 (permalink)
Aside from aero and rolling resistance, I've found that some cars can have more drag from the transmission in neutral or clutch disengaged. More of a DCT wet clutch thing though, just throwing that out there.
Old 07-18-2015, 10:15 AM   #13 (permalink)
Lean Burn Cruiser!
BabyDiesel's Avatar
Big Blazin' - '88 Chevrolet K5 Blazer Silverado
90 day: 14.97 mpg (US)
Chili - '00 Honda Insight
Gen-1 Insights
House of Tudor
Team Streamliner
90 day: 72.29 mpg (US)
Your Fiesta is an unfortunate fusion of low weight and high Cd, along with a CdA of 22-24 based on your measurements. None of which are good. But you don't bring a car to Ecomodder to keep it the same!
I'm reminded of a picture that Aerohead has posted on several threads. It details the Cd changes from different rear hatch slope angles. IIRC, your car might be along the highest Cd possible. I 'll see if he can post it on this thread.
In my 98 Escort, I did drag reduction to reduce the Cd from 0.33 down to 0.269. After coastdown testing, I stripped my entire interior except for my driver seat for cleaning. This was about 175 pounds lost (~80 kg). Immediately, my coasting distance plummeted! P&G was pointless and my points to start coasting on my trips meant nothing anymore. I added the weight back and the coasting improved, and overall mpg improved.
If you do a lot of highway driving, you might could add weight without much of a penalty. The coasting distance would improve even without aero mods.
Remember, thank a fellow EM'er for a helpful post!!!
I hypermile better in my cowboy boots
Past threads:
ZX2 modding thread
Ecomodder's Top 10: How they do it!
ZX2 Aerodynamics: Shooting for 0.15 Cd
ZX2 coast-down testing for Cd & Crr
The Following User Says Thank You to BabyDiesel For This Useful Post:
RPM (07-19-2015)
Old 07-18-2015, 01:58 PM   #14 (permalink)
Here are some drag tables
BabyDiesel (08-02-2015), RPM (07-19-2015)
