View Poll Results: Paint skirts White, or Paint Skirts Green - And Decal?
White Skirts with Ecomodder.com decal on them 2 9.52%
Green Skirts with Ecomodder.com decal in rear window 10 47.62%
Green Skirts with Ecomodder.com decal in side window 9 42.86%
Voters: 21. You may not vote on this poll
Old 06-30-2008, 01:13 PM   #1 (permalink)
gascort's Avatar
Gascort RIP - '93 Ford Escort Wagon
90 day: 43.01 mpg (US)
WifesCruze - '11 Chevrolet Cruze LT
90 day: 31.1 mpg (US)
$2.50 Wheel Skirts
I'm on the first aero mod... I made sure to make it cheap and removable so I can do testing to determine its influence on my FE when I have a dependable daily commute.
I used sheetrock corner-brace, some recycled coroplast campaign signs, sheet metal screws, washers, and duct tape. Paint will come later.
As for the poll, I'm trying to decide... paint the skirts white and put the ecomodder.com decals on them (to make the decals stand out), or green to match the car?
More details than you'd ever want to know about what I did are on my blog, along with more pictures.
Matt
Gasoline, Wind, Solar, Gravity Hybrid-to-be! http://www.scientificmethodfueleconomy.blogspot.com/
Old 06-30-2008, 01:45 PM   #2 (permalink)
Veggiedynamics
Volt12 - '12 Chevy Volt base
nice !! love the scort wagons!
Old 06-30-2008, 10:32 PM   #3 (permalink)
Recycling Nazi
Bror Jace's Avatar
Blue Bullet - '06 Honda Civic Sedan LX
90 day: 35.68 mpg (US)
Thumbs up
gascort, love the cheapie skirts!
Still, I think you should have sunk another $0.99 into them and spray-painted them black first.
Maybe I'll score some free plastic once the lawn signs come out in front of the coming election.
--- Bror Jace
Old 06-30-2008, 10:33 PM   #4 (permalink)
Recycling Nazi
Bror Jace's Avatar
Question
Hey, I just looked again, why haven't you deleted the roof rack, yet?
--- Bror Jace
Old 06-30-2008, 10:36 PM   #5 (permalink)
gascort's Avatar
The people have spoken... Green Skirts!
I can't find my ecomodder.com decal though! I should've installed it the minute it arrived here. Hopefully it turns up in the next day or two.
I also finished a bit more... pics here and on my blog! I'm still planning on taking all of this off in August when I start work (teaching) again, so I can compare FE scientifically.
Pictures: Front end factory, then modded, then the whole car. Yes, I'm planning on trimming the front block up tomorrow.
Matt
Old 06-30-2008, 10:39 PM   #6 (permalink)
gascort's Avatar
I'm going to have to fill in some holes and I want to get data on exactly how much the removal affects my FE. I don't want to take it off, then reinstall, then take it off again.
Have no fear, my friend. I've already removed the headliner and loosened all the bolts - she's ready to be destroyed!!!
Oh, and the black ended up not being necessary - Krylon Fusion plastic paint is incredible!
Old 06-30-2008, 10:45 PM   #7 (permalink)
Veggiedynamics
you have to camm back that thing!!, wow, looking great !!
Old 06-30-2008, 11:28 PM   #8 (permalink)
Iwishthiswasamanual - '98 Ford Escort ZX2
90 day: 32.95 mpg (US)
Wow. Having the fold at the back makes it much easier then trying to make the whole thing curved. Def going to give wheel skirts a chance again.
Just not really feeling screwing into body, so I'm going to have to try some other ideas.
Friend suggested .... using that mesh fiberglass that hardens when you put whatever on it. Sorry, forgot exact names. But having that go on inside lip of wheel well and around to coroplast.
Old 07-01-2008, 09:21 AM   #9 (permalink)
gascort's Avatar
Believe me, I would never have done this to my mustang, but I bought this car for fuel economy experimentation only, so I'm not worried about damaging it.
I think you're referring to fiberglass and hardener, or bondo, to do your wheel. I might try to make a fiberglass shell based off the skirts (using them as a mold or form) later, depending on how long the coroplast and duct tape last.
I also noticed yesterday that I can take the wheels off without removing the skirts - should just have to remove the bottom two screws and lift the car up by the body, and the wheel and tire should come free. Loosening the lug nuts without having the tire on the ground will be the real trick.
Did I hear Coroplast Cammback? Oh yes, but I don't think I'm going to make it today. I need to figure out how it will work at the top of the hatch (my hatch top slides below the roof level when it's lifted - I need to look at Andrew's civic design again and see if he had the same issue.)
Matt
Old 07-01-2008, 07:48 PM   #10 (permalink)
Recycling Nazi
Bror Jace's Avatar
Arrow
Yes, green looks better than black. I'll have to see if they have a dark blue that will closely match my blue Civic.
I'm thinking of mocking up something on my '06 Civic using coat hangar wire and cardboard. If it it works, I'll try the same thing using sturdier materials.
Problem is, even if I paint the cardboard on both sides, one rainstorm will probably ruin them.
As for the roof rack, I'd use RTV to seal the holes. Will seal well, can last a long time and if you have to remove it, well, any screw or bolt can work its way through the stuff no problem.
--- Bror Jace
DIY: plastic rear wheel skirts (Geo Metro) MetroMPG DIY / How-to 57 06-12-2014 09:16 AM
DIY Rubber Front Wheel Skirts newtonsfirstlaw DIY / How-to 32 05-19-2011 07:45 AM
I got accosted for wheel skirts! lovemysan EcoModding Central 33 10-12-2008 07:12 AM
wheel skirts for 91 civic bbb3108 Aerodynamics 11 03-11-2008 12:39 AM
Wheel skirts for the aerodynamically minded Daox Aerodynamics 14 01-27-2008 11:23 PM
