Old 05-02-2012, 11:17 AM   #1 (permalink)
roller - '08 Toyota Corolla
90 day: 41.49 mpg (US)
big blue - '91 Dodge W250 LE
90 day: 18.33 mpg (US)
Power steering pump delete
Has anyone had any luck with a power steering pump delete?
I'm kicking the idea around but want to hear your opinion on the matter.
Old 05-02-2012, 12:58 PM   #2 (permalink)
I've done it; I like to think it helped but lacking instrumentation I can't say if it did or by how much.
Old 05-02-2012, 01:35 PM   #3 (permalink)
been there done that
Old 05-02-2012, 02:55 PM   #4 (permalink)
Moderator
Vman455's Avatar
Pope Pious the Prius - '13 Toyota Prius Two
90 day: 51.62 mpg (US)
Tycho the Truck - '91 Toyota Pickup DLX 4WD
90 day: 22.22 mpg (US)
I removed mine last summer. Nothing spectacular, but I was able to hit 40+mpg for the first time shortly afterward (in normal driving; I wasn't hypermiling at the time. Also, no aerodynamic mods to the car at the time).
UIUC Aerospace Engineering
www.amateuraerodynamics.com
Old 05-02-2012, 03:10 PM   #5 (permalink)
EtOH
Allch Chcar's Avatar
Cordelia - '15 Mazda Mazda3 i Sport
90 day: 37.83 mpg (US)
Unless you swap to a manual rack the power(less) steering rack needs fluid or you'll ruin the bearings. If you just loop the hoses it'll eventually run dry and emit a high pitched squeaking noise. So it needs a small reservoir where you can add PS fluid to keep the rack happy.
Just some info I gleaned.
-Allch Chcar
The Following User Says Thank You to Allch Chcar For This Useful Post:
MurrayRothbard (03-12-2024)
Old 05-02-2012, 03:45 PM   #6 (permalink)
Shady petro-addict
slotech's Avatar
B4 - '97 VW Passat TDI
Worth the effort
A worthwhile mod, especially for HWY miles or lighter vehicles. After I pulled the pump, the belt was able to re-route and let me also delete an idler pulley. No huge friction losses there, but it still felt good to throw that thing over the fence. IIRC, had to locate a dremel tool and grind away a bit of the aluminum timing cover [1st gen saturn dohc] to allow for the new path of the belt. Took some trial and error to find the correct length serpentine belt to get acceptable tension with the reworked geometry. Has held together with no weird belt wear for at least 35k mi.
Still to do: find a better option for fluid reservior or a manual rack out of the junkyard, ATM original PS hoses tee onto a length of hose with a vent on the end to keep dirt out.
Best of luck -
M.David
Old 05-02-2012, 08:29 PM   #7 (permalink)
JacobAziza's Avatar
Big Orange Work Truck - '83 Ford F-250
90 day: 27.54 mpg (US)
Jessica's - '04 Toyota Matrix
90 day: 41.21 mpg (US)
Ninjette - '01 Kawasaki Ninja EX250R
My girlfriend had never done so much as an oil change on her own, but last year she removed her power steering pump all on her own in preparation for a trip across the country (CA to VA). As Slowtec said, it took some trial and error to find the right length belt to bypass the pump entirely (which would have been running dry).
Steering effort in her Matrix is noticeably higher, but still pretty easy, and definitely not enough to warrant a manual steering rack.
We haven't been topping off the fluid (never thought to check) - hopefully we aren't going to burn up the rack anytime soon! Maybe I better check on that...
Originally Posted by Piwoslaw View Post
A few months ago I returned home just as my neighbor pulled into his driveway. It was cold (around freezing) with some rain and sleet, and he yells to me: You rode your bike? In this weather?!?
So the other day we both returned home at the same time again, only now the weather is warm, sunny, with no wind. And I yell to him: You took the car? In this weather?!?
Old 05-02-2012, 08:41 PM   #8 (permalink)
Smaller crank drive pulley (10% reduction) Small but measurable improvement.
Old 05-02-2012, 08:47 PM   #9 (permalink)
Moderate your Moderation.
90 day: 45.22 mpg (US)
I've never added fluid to a rack (3 of my own cars) after deleting the PS pump. I loop the hoses, and leave whatever fluid is in there, then forget about it. I've also removed the hoses and plugged the ports before.
Many power racks can be de-powered by elminiating the hydraulic seals in them, which cause drag.
I've never heard nor read about bearing wear due to removing the PS pump and not adding fluid until now. Do you have a source that we, as a community, can evaluate?
Old 05-02-2012, 10:42 PM   #10 (permalink)
The 'Vic - '96 Honda Civic DX
90 day: 39.3 mpg (US)
I have only removed my power steering belt and have been running it for quite some time. I just went and reviewed my fuel logs and the power steering delete and an upper grille block were responsible for a 10.3% increase in MPG.
Civic Build Thread
Your grammar is appreciated.
3.788 Civic CX final drive, air dam, 1st gen HCH 14" wheels and Michelin Defender 175/65R14 LRR tires
