Old 08-13-2014, 10:30 PM   #1 (permalink)
precision measurement of fuel
I was trying to figure out how to measure small quantities of fuel in my 1965 Honda 50. With a 3 liter fuel tank and an estimated 145 MPG, I think I have found a solution.
Take a plastic oil container of 1 quart capacity. Put a hole in the top and stick a piece of plastic fuel hose through the hole. Fill the container with fuel, remove the gas cap, stand the container with the cap on the fuel filler opening. Lower the seat to hold it in place and let gravity do the job.
Remove the container and carefully measure the difference in the amount of fuel in the container. Easily capable of measuring down to 1/2 ounce of fuel.
regards
Mech
The Following 2 Users Say Thank You to user removed For This Useful Post:
California98Civic (08-14-2014), niky (08-14-2014)
Old 08-14-2014, 04:06 AM   #2 (permalink)
Wish you could do that with a car!
Old 08-16-2014, 07:14 AM   #3 (permalink)
Yella Peril - '80 Mercedes 240D sedan
A digital scale would give pretty good accuracy.
Old 08-16-2014, 07:23 AM   #4 (permalink)
A local racing school once did that for a fuel economy demonstration. They made a fiberglass hood, then cut a hole in it and added a mount for an upside down two liter soda bottle attached to the fuel rail.
This was on a direct injection diesel, however... so I don't know if the lack of a high speed fuel pump on the tank side hurt it or if there is a high pressure pump on the rail that pulls in the fuel.
Of course, it's a very impractical way to do things...
