Old 01-28-2016, 07:33 PM   #11 (permalink)
Focus - '01 Ford Focus SE Wagon
90 day: 32.38 mpg (US)
Originally Posted by jedi_sol View Post
That's a nice looking grill block. Do you have pics of the build process?
I took the factory grill out and laid it on the back side and traced out with a sharpie. Then I cut it out leaving the line and 1/16" or so. Then just used a red scotch roloc and kept shaving down to fit. Zip ties are throgh grill supports that also line up with vertival reinforcements in bumper openings.
Similar process to interiors I've done in street rods so it was quick/easy haha.
The Following User Says Thank You to yellow2000sr For This Useful Post:
jedi_sol (01-28-2016)
Old 01-28-2016, 07:52 PM   #12 (permalink)
VanDelay - '89 Ford Econoline E-150 XL
90 day: 15.93 mpg (US)
Old White Civic - '98 Honda Civic LX, AT
90 day: 33.18 mpg (US)
where'd ya get the 1/8" abs?
Old 01-28-2016, 07:57 PM   #13 (permalink)
4x8 sheets from Total Plastics Inc in Harrisburg PA. A buddy owns a sign shop and gets his chloroplast from there. I'll probably be buying some black chloroplast or the aluminum foam core in the future for a belly pan.
I use the 1/8" for front door panels in vehicles.
Old 01-29-2016, 07:05 PM   #14 (permalink)
Spaced out...
spacemanspif's Avatar
The New Focus - '07 Ford Focus ZX5
90 day: 32.44 mpg (US)
Gonna need to see some hot rods pics now that you mention them.
-Mike
2007 Ford Focus ZX5 - 91k - SGII, pending upper and lower grill bocks - auto trans
1987 Monte Carlo SS - 5.3/4L80E swap - 13.67 @ 106
2007 Ford Focus Estate - 230k - 33mpg - Retired 4/2018
1995 Saturn SL2 - 256K miles - 44mpg - Retired 9/2014
Cost to Operate Spreadsheet for "The New Focus"
The Following User Says Thank You to spacemanspif For This Useful Post:
Xist (01-29-2016)
Old 01-29-2016, 09:51 PM   #15 (permalink)
Welcome to the site! Good luck with your project!
You will soon have as many modifications as I have in three years!
Which of us needs to do something about that?
Edit: Power steering deletion? That is one of the few modifications that I have made, that and an all-in-one grill block and air dam. It is supposed to give a minor economy improvement, as well as fitness. Win-win, right?
It might be easier than fixing your power steering leak. My first car leaked power steering fluid. It ate through the alternator belt, the rack and pinion, and who knows what else, but it obviously was not slight!
Edit2: What about smooth wheel covers? Many members just zip tie circles of coroplast or screw on pizza pans. I wanted to be different, so I mounted aluminum pizza separators, but I did not like my mounting method. Here is a good one: http://ecomodder.com/forum/showthrea...orn-14306.html
Or if you have hubcaps: http://ecomodder.com/forum/showthrea...vex-14958.html
Old 02-05-2016, 04:36 PM   #16 (permalink)
90 day: 57.73 mpg (US)
Any updates?
Is that the factory air dam?
I only see one fuel log entry!
Old 02-05-2016, 05:29 PM   #17 (permalink)
Next pay I'm going to get my tires rebalanced with sticy weights to remove the clamp style weights, then install pizza pan wheel covers
Also going to look into a scan gauge or something similar to monitor coolant temp and stuff.
Old 03-03-2016, 09:37 PM   #18 (permalink)
Just updated fuel log. Missed a week tho.
Just oredered an UltraGauge. Thinking about installing a orange LED into low fan side and red LED in high fan side on the cluster surround. I know that I can set an alarm on the UltraGauge for temp and stuff tho. I know low fan will come on after I get off the highway when it's over 55° out with the full lower grill block (I do have 2 2" holes in the center now).
I'm off this Sunday through Thursday so maintenance is planned. Timing belt, new factory radiator ducting from bumper to rad so the air that does make it theough blockoff holes goes through the rad, and an oil/filter change.
Old 03-04-2016, 02:03 PM   #19 (permalink)
If you do this, please document the project. I've thought of doing the same, but (surprise, surprise) haven't gotten around to it.
Old 03-09-2016, 01:01 PM   #20 (permalink)
Removed the complete roof rack yesterday. It was attached to the roof skin with rivnuts. I drilled them out then drilled the hexagon roof holes slightly larger to 1/2". Then I got 1/2" plastic caps from the hardware store and siliconed under the cap and snapped them in.
The Following 2 Users Say Thank You to yellow2000sr For This Useful Post:
Joggernot (03-10-2016), Xist (03-10-2016)
