Old 02-04-2012, 10:41 AM   #211 (permalink)
Cd
Ultimate Fail
Cd's Avatar
Old 02-04-2012, 07:26 PM   #212 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
Originally Posted by Sven7 View Post
Edit: If anybody knows, what kind of angle should I expect to get away with on the bottom side of the tail? It would save me some tufting time.
Ideally , 3° on a liftback, starting at the rear axle.
Disconnected the battery, reconnected it, and the car runs like normal... weird.
That tends to reset its systems, and faults if possible.
The Following User Says Thank You to euromodder For This Useful Post:
Sven7 (02-05-2012)
Old 02-05-2012, 02:19 AM   #213 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
F*CK. This. Sh*t.
I reinstalled the front belly pan and air dam, shortening the air dam an inch and a half or so. Drove up to a friend's house. On the way back, I was EOC'ing when the lights dimmed and the car would not start back up. Coasted to the side and called AAA. It was real fun to hear my mom's reaction when I told her I was EOC'ing. Real, real fun. Also real fun to sit in my car for ~30 minutes when it's 27* outside and I forgot my hat.
ALWAYS keep a blanket and a snack in your car in the winter. I wrap a CLIF bar inside a fleece blanket just in case. The blanket came in handy.
Suspecting battery or charging problems. GAHH I am going to test the battery and install the fuel pump. If those don't work I'm getting rid of the car. Having a car at college is a privilege, not a necessity. It's really pissing me off.
Is this the end? by Tyler Linner, on Flickr
On the bright side, the drivers front wheel with the smiley face really, really amuses me
Old 02-05-2012, 02:59 AM   #214 (permalink)
CigaR007's Avatar
GreenTurtle (Retired) - '01 Toyota Echo Sedan
90 day: 44.85 mpg (US)
Zulu - '14 Honda CR-Z BASE
90 day: 49.05 mpg (US)
Glad you are ok !
Old 02-05-2012, 03:33 AM   #215 (permalink)
And the moral of the story? Don't turn your engine off if you're not 100% sure your battery is good.
Old 02-05-2012, 03:39 AM   #216 (permalink)
Sven7's Avatar
I think I have driven almost 100 miles on this battery so far... it seemed to be pretty solid. No real numbers but it should have died before now if it were already bad.
Old 02-05-2012, 04:40 AM   #217 (permalink)
TurnpikeCruiser's Avatar
Big Merc - '94 Ford F150 XL
The Cherry Bomb - '88 Mercury Grand Marquis LS
Luxoliner - '07 Mercury Grand Marquis LS
Team Panther
90 day: 23.63 mpg (US)
Disconnected the battery, reconnected it, and the car runs like normal... weird. Now I have an extra fuel pump in case it actually breaks.
Modern by Tyler Linner, on Flickr
This, by far, is one of the neatest paint schemes I've seen on a car. I'd vote to replace the badger with a continuation of this...if you keep the car.
The Following User Says Thank You to TurnpikeCruiser For This Useful Post:
Sven7 (02-05-2012)
Old 02-05-2012, 05:40 AM   #218 (permalink)
euromodder's Avatar
I'd vote for a digital camo scheme - these disruptive schemes are so 1940s
Old 02-05-2012, 06:16 AM   #219 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Maybe bigger if you EOC with lights on a lot.
Old 02-05-2012, 05:18 PM   #220 (permalink)
Sven7's Avatar
Cruiser- thanks! That seems to be the plan.
Modder- naww I like retro stuff.
Jakob- Is that a home built battery?
Looks like Tuesday is the earliest I can do something. My friend is supposed to bring me my old battery.
