Old 10-28-2012, 10:56 PM   #641 (permalink)
92 Camry - '92 Toyota Camry LE
90 day: 26.81 mpg (US)
97 Corolla - '97 Toyota Corolla DX
90 day: 30.1 mpg (US)
Red F250 - '95 Ford F250 XLT
90 day: 20.34 mpg (US)
Matrix - '04 Toyota Matrix XR
90 day: 31.86 mpg (US)
White Prius - '06 Toyota Prius Base
90 day: 48.54 mpg (US)
=D, too bad I don't get much better than 41 my self while ecomodding. No boat tail though to deal with. Looking forward to the offroading video ecomodder style .
Old 10-29-2012, 02:55 PM   #642 (permalink)
Master Ecomadman
arcosine's Avatar
sc1 - '98 saturn sc1
Team Saturn
90 day: 43.17 mpg (US)
rans - '97 rans tailwind
90 day: 28.25 mpg (US)
red bug - '00 VW beetle TDI
big tractor - '66 ford 3400
90 day: 58.42 mpg (US)
RV - '88 Winnebago LeSharo
90 day: 16.67 mpg (US)
41 mpg isn't bad, I'm getting 52 mpg so far this tank at 65 mph highway in the sc1 without much drafting. I guess those aliens like to hide out on those remote logging roads, good retrieval.
- Tony
Old 10-29-2012, 07:25 PM   #643 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
Gas tank is leaking. Probably scraped it offroading. Gotta patch it tomorrow yayyy
Edit for photo at the rally
At the Stage by Tyler Linner, on Flickr
Old 10-29-2012, 08:53 PM   #644 (permalink)
Do more with less
OD - '05 Ford Econoline
90 day: 18.64 mpg (US)
90 day: 49.71 mpg (US)
90 day: 28.08 mpg (US)
I had a fuel leak in 2011 in my minivan. It cost about 15-20% of fuel usage. Perhaps you are burning less than you think.
Noah Webster, 1787
Old 10-29-2012, 09:39 PM   #645 (permalink)
Sven7's Avatar
That would be pretty cool. I wonder how much could leak out in those 9 hours of driving.
And Friday night, marshalling- this was so damn fun. This was one of almost 30 cars that went by making music like this. All in all we worked four stages on Friday and spectated one on Saturday (missed a couple due to off-roading crap).
Old 10-30-2012, 04:53 AM   #646 (permalink)
My brother left a car with a leaking tank parked at the curb in front of my house (in the 70s) and went to South America. Soon there was a puddle of gas at the curb. Not much will stop leaking gas, definitely not duct tape, not bubble gum.
What does work? Rub a potato on it.
Old 10-30-2012, 07:42 AM   #647 (permalink)
Deadly Efficient
Tango Charlie's Avatar
Olivia - '03 Pontiac Vibe base
90 day: 36.01 mpg (US)
R2-D2 - '00 Honda Insight
90 day: 58.81 mpg (US)
There's plenty of sealants that will work. The trick is to drain the tank and make sure the area that you're applying the sealant to is clean and dry.
Aircraft grade fuel tank sealant.
-Terry
Old 10-30-2012, 10:52 AM   #648 (permalink)
Sven7's Avatar
I have some gas tank sealant I bought last year. Will probably use that...
...and look for Geo's on Craigslist.
Old 10-30-2012, 11:47 AM   #649 (permalink)
christofoo's Avatar
00C - '00 Toyota Corolla
90 day: 43.54 mpg (US)
Originally Posted by Sven7 View Post
An IDGAF attitude is just one service I offer.
The belly pan structure was bent and sagging to I just say to H E double toothpicks with it and pulled the damn thing off. This came with it. From where? I don't even want to know, but the frame rails are very ugly.
I expect a belly pan would help prevent rust (and bits like that eventually falling off the car) but more especially if the belly pan were added earlier in the car's life.
Any mistakes you think you might have made on your belly pan the rest of us might do well to avoid?
Old 10-30-2012, 01:07 PM   #650 (permalink)
Sven7's Avatar
Yeah, the rust ship has sailed. I'm somewhat afraid of how much the frame is rotting.
Things to improve upon:
-Make SURE the structure is super duper strong as well as supported somewhere in the middle. Not "strong enough", but rock solid. I used two thin C-channel aluminum bars as the main support structure and it wasn't enough. I'd like to use ABS plastic next time for the skin.
-Seal it up on the sides. If you don't know how you're going to do this, don't do it at all yet.
-Make provisions for wheel strakes, boat tail attachment (got that one) and whatever other additions you'd like to make. This means reinforcing it or building it heavier in critical areas.
-Any parts that you'll regularly take off- under the oil drain plug and oil filter, for instance- should be attached using clips, hinges or a combination. Zip tying it up every 6 months is not fun.
-Don't off-road it (oops). Anything you build, short of plate steel, will be of no consequence to a rock.
