06-04-2012, 08:53 AM
#91 (permalink)
Deadly Efficient
It does appear to straighten out a bit, at the very end. Also, would it be better to shave down/round off the "shoulders"?
This is only meant in the humblest of constructive criticism. The tail is looking awesome and I am looking forward to what kind of numbers you achieve!
-Terry
The Following User Says Thank You to Tango Charlie For This Useful Post:
06-04-2012, 08:36 PM
#92 (permalink)
MPG Militia HMV-25E80+A
Neil- You could very well be right. I've run out of time/money for the rally this weekend and am going to live with it like it is for a while. I do know that the original foam has shrunk and I haven't done an overlay yet, so I'm not sure where I stand at all  . Oooooooh yes I have seen those strakes, and they are on the "to do" list  .
TC- Any and all advice is accepted and appreciated. Those very corners have nagging at me for a while, but I was leaning toward the thought that if I did round them like you suggest, that the path way that the air travels from the front corners of the car would exceed the max angle of 21/22 degrees. Does this make any sense or am I over thinking it?
Thanks very much guys. I'm kinda crashing my way through here and can use all the guidance I can get  .
Reason: Was typing drunk.
06-04-2012, 08:44 PM
#93 (permalink)
Latest, latest pics. This should be it for a while. I have got other issues that are demanding my attention, but don't worry, I ain't done yet  .
The color is rattle-can Rustoleum Blue. Close enough for now. The blue that I eventually paint it will be a bit darker and metallic.
The Following 2 Users Say Thank You to JethroBodine For This Useful Post:
06-04-2012, 10:01 PM
#94 (permalink)
Ultimate Fail
I was just watching Blue Planet last night and was admiring the streamlining of the Blue Whales.
Looking very similar, and now even more so.
06-04-2012, 10:05 PM
#95 (permalink)
Ultimate Fail
Time for another tuft test !
BTW, do you plan to add any rounding to the front end ?
06-05-2012, 08:22 AM
#96 (permalink)
Deadly Efficient
Only a tuft test will tell for sure (well, that and a day in a million-dollar-an-hour wind tunnel...but you know what I mean). You may be thinking somewhat two-dimensionally about the 21 degrees. I have heard that you can go progressively a bit steeper, if you're getting air "filling in" from an adjacent side via a rounded corner. Which makes sense to me.
Tuft testing is time and labor-intensive, fiddly, and complicated to pull off successfully. But oh, so worthwhile.
-Terry
06-05-2012, 08:44 PM
#97 (permalink)
Cd- Might get around to rounding the front eventually, but I think there is a lot left to do to the rest first. If there is some down time during the weekend, maybe I can organize an impromptu tuft session. I bet there will be enough hands there to get it done fairly quickly.
08-07-2012, 06:58 PM
#98 (permalink)
Wiki Mod
quick question, how did you seal the tail to the car, or did you fiberglass right to the car?
08-07-2012, 09:22 PM
#99 (permalink)
Went right out overlapping the original body. Sanded the metal clean first. I'll be spending some time on the tail before Bonneville, but not as much as I'd like.
09-20-2012, 04:28 PM
#100 (permalink)
Not banned yet
Blue - '03 Chevy S-10, LS
inspiring thread.
